Question about Hitachi 50SBX70B 50" Rear Projection Television
Watching tv and it turn off
My tv shut off by itself what can i do ....it make a little noise before it shut off
    President:
  • 4,402 Answers
Have you tried unpluging it and plug it back in?
there is a service bulletin out for this set i would have this done first!
This update covers to the following Hitachi models and chassis
46UX50B/51K, 50UX52B/53K, 60UX54B/55K, 50SBX70B, 60SBX72B, 70SBX74B. All projection televisions using the AP73 & 74 chassis's From Dennis Viereck
SYMPTOM:
Intermittent loss of Raster, On Screen Display, sometimes sound. BUT ALWAYS HAS HIGH VOLTAGE! Also removing power and reapplying it again restores operation.
THE PROBLEM: There is a lack of a secondary ground for the CRT Dag connected to each CRT board. You can identify this missing ground on the CRT board by locating two vacant pins on each CRT driver board near the CRT socket. The connector is named P801, P831, and P861 relative to each board. The pin nearest the socket is the ground pin in question. The pin furthest from the socket is connected to the cathode of the CRT.
OBJECTIVE: Run a separate ground wire from the "GROUND" pin on each CRT board to the chassis ground. You can use the circuit board mounting screw on the frame under the green CRT. See drawing below.
DIRECTIONS: Obtain 3 wires 10, 14, and 18 inches long. The wire is 18 gauge stranded with an insulated jacket. Attach one wire to each ground pin on the CRT socket. Choose the correct length of wire so that all wires will connect to the circuit board mounting screw near the center of the chassis frame.
EXPLANATION: The extra ground is needed if an internal arc occurs in the CRT. This energy must find a path to ground. Before, the only path to ground is through the signal ground wire on the RGB drive connector. This thin wire does not go directly to chassis ground and is inadequate ground for the CRT dag. If the energy level of the discharge is high enough it may corrupt the data flow on the data & clock lines or negatively effect the OSD microprocessor. Since electricity takes the shortest path to ground, the additional ground wire will route the majority of that static pulse to chassis ground quicker and reduce the possibility of corrupting operation of the OSD processor.
http://www.anatekcorp.com/faq/archprotv.htm
Posted on Jan 04, 2008
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
I go to turn it on and it sizzles and shuts itself off.
Replace the flyback. You need the 259296 flyback replacement kit which has the flyback related capacitors and the CD with detailed instructions. The kit is available at www.tvrepairworld.com
Sep 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
Please update this with a make and model number. WIthout that information there is little assistance I can provide. Also, does this occur all the time or only after the set has been on for a while?
Thanks,
Dan
Apr 08, 2008 | Televison & Video
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
193 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
