Question about Canon PIXMA MP780 All-In-One InkJet Printer
How do you remove the waste ink absorber pads?
I'm getting the "waste ink near full" message. I know how to reset the counter, but I saw Darklord1's advice to MissBetty re:cleaning the pads, and I'd like to do that first. I downloaded the manual he mentioned, but I didn't find in it instructions for removing the pads. How do you get into the printer to remove them?
Thanks for your help!
  • 4 more comments
  • Anonymous Jan 08, 2008
    cant find the pads under the cartridge
  • LifeofRiley Jan 08, 2008
    Okay, I figured out how to get to the pads. First, take the sides and the top off the printer. Basically, follow the screws and pray when you snap it off the sides. The top comes off too, though it'll remain attached by wires in the back right corner, so plan ahead for having the top 1/2 of the machine laying upside down by the back right corner. I'd recommend resting it on a piled up blanket/pillow/rags (something you don't mind getting dirty with indelible ink).
    You can remove the spongy pads from their containers with your fingernails. There's a long, thin one dead center (6ish" by 1/4"), one to the left of that (mostly covered by a thin plastic piece which routes the ink downward and which also can come out with your fingernails), and two to the right of the long one.
    Now, how do I get to the waste ink well(s)? They're obviously full--in messing around with the printer, trying to figure out how to get inside, I tipped a bunch of ink on the table. I might have emptied them, but i'd rather make sure.
  • LifeofRiley Feb 07, 2008
    The first time I put it back together, the printer didn't work either. For two reasons: The first was because of loose connections. Check the back right-hand corner. There are two short ribbons that unplug easily--if you can reconnect them, you might get power back. The second reason was and remains a mystery. We had everything together, the power was on, but when the ink cartridges tried to move into position, there was a terrible grinding sound. We pulled everything apart again and looked around. Saw nothing. Put it back together. Still grinding. Pulled it apart. Put it back together. Worked fine. A month later, the printer's still going strong.
    Sorry, holborn, but that really only works once or twice before you chance ruining the printer. Reseting the counter allows you to keep printing, but it doesn't get ride of the waste ink, which eventually will overflow.
  • Loosenit Feb 11, 2008
    hi I have the same problem with my ip3000 canon I need to get the waste pads out, I can get the outer shell off but I don't know where to go from there, it all looks heap complicated and I don't want to wreck it. I need step by step instructions on how to get to the pads if I have them I don't mind doing the rest ie washing, drying, please help I have looked everywhere for this information.
    I love this printer and don't want to change.
  • Anonymous Feb 12, 2008
    do you have the reset codes for the MP 780
    I've had the waste tank cleaned but still get the check printer flashing light...thanks Rick
Well, I tried that, I could not locate the pad anywhere and after I put it back together, now it will not turn on at all.
Posted on Feb 07, 2008
    Master:
  • 619 Answers
All above suggestion and solution are okey/
After opening printer best way to clean it that your hand not getting dirty wear rubberize gloves take some old injectable cyrin, suck it put into container with fine screen filter/ nothing left ink ,injection cyrin connot suck anymore .replace the pad if available or clean it /soak w/detergent wash and dry..
Posted on Jan 10, 2008
    Problem Solver:
  • 17 Answers
No need to open the printer.....you only need to reset the counters. use canon reseter!!!
  • Foday Sankoh
    Foday Sankoh Dec 31, 2013
    i need that software pliz
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Ink absorber full
If it is nearly full, you can press cancel / resume to ignore the message. Once the ink absorber is completely full it will prevent you from printing and it will need to be emptied and have the print counter reset.
This is probably something you want them to service.
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Technical Support is available for Customers in Canada at 1-800-OK-CANON
Please leave feedback if you found this helpful. Thanks.
Mar 17, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
'Unable to clean' message came up - no debri or paper clips in printer and inks full. Turned off and left overnight. Still no good. Please help with advice and also expert in area of Bodmin Cornwall. We...
This msg indicates that the Waste Ink pad is full in your printer, you will need to reset the waste ink counter and replace the waste ink pad inside...
to reset the counter, Turn Off your printer first... then while holding the Menu button, switch ON the printer and release the button when you see the word Maintainence ... then enter 80 using the number pad and press OK. Press the Start button until the word Purge appear on the screen... then press number 2 7 8 3 ...
to exit.. press 9 9 and then switch off and on back your unit.. this will reset your printer but it's better to have the pad replaced to avoid leakage.
Jan 20, 2011 | Brother MFC-620CN multifunction Color...
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Waste ink nearly full
Hi and welcome to FixYa!
If the waste ink pad is nearly full you will need to have it replaced or reset the purge counter to get rid of the message. Please be informed that even the message is resetted theres a tendency that the inkpad will overflow and you may find spill at the bottom of the printer.
Hope this helps and thank you for using FixYa!
Nov 29, 2010 | Canon Office Equipment & Supplies
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer sending message
Waste ink tank/pads getting full.
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need to actually get a SERVICE MANUAL, to refer to that removal procedure.
You may want to try doing a general search on the "Fixyourownprinter.com" printer repair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.
Jun 22, 2009 | Epson Office Equipment & Supplies
Waste Ink Absorber is almost full message every time I print
you need to change the inks waste pads, and reset the ink waste counter in service mode.
you can just reset the ink waste counter and still use the machine but it will probably start leaking a bit of ink after a while unless you sit it on something to absorb the excess ink.
to reset the ink waste count just do a search on the web and you will find it pretty easy to do.
Apr 01, 2009 | Canon PIXMA iP1600 Printer
The printer is indicating "waste ink near full"
Hey,
The waste ink pads should generally be around the cartridge carrier, or below, possibly at the bottom of the printer.
have a look at this page for instructions on how to reset the counter after the waste ink pads have been cleaned or replaced.
http://www.allthefaqs.net/forum/viewtopic.php?t=3770
Let me know if you need anything else.
Thanks,
Ekse
Mar 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
436 people viewed this question
old marine
old marine
