Question about Sony PlayStation Portable (PSP) Console
Need help with wireless internet connection
I have a wireless router but don't know how to set up to play online can you help. Maybe give me instrustions or the location to find the manual to insturct me on how to complete it. Thank you
  • Anonymous Jan 12, 2008
    (ps3) wen i try 2 connect internet via wireless router it says:
    obtain ip address succeeded
    internet connection failed
    this is a dns error
    (80710102)
    pls help ime at a loss
    Problem Solver:
  • 5 Answers
U cant watch vids go to internet click on scan
Posted on Jan 04, 2008
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
How do you get the internet on this my says no compatible access point in range check your connection setting under internet opion and try again error code 051099
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
  1. Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step.
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
mr_fix3er_0.png 2- Scroll over to the third page, and select "Internet."
mr_fix3er_1.png 3-Now choose "Connection Settings."
mr_fix3er_2.png4-Click on "None" for "Connection 1."
mr_fix3er_3.png 5-Click on "Search for an Access Point."
mr_fix3er_4.png 6-The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network.
7-What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
mr_fix3er_5.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_6.pngWEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_7.pngWPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
  • Other suggestions :
  • Make sure your router is set to broadcast in "b" or "mixed" mode. If your wireless router is transmitting in "N" only mode, you will need to switch it to "b/g" or "mixed" mode. For help accessing your router's settings, click here and select your router brand and model (if available). Most routers will have this setting in the "broadcast settings" menu.
    • Check for wireless interference, which can affect the signal strength to the Nintendo DS. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Nintendo DS is an open area without objects or electronics blocking the signal.
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • Still stuck? We can help! We have found that simply erasing the old connection file and creating a new connection to your router may help. Click the button below for a step-by-step guide. If at the end you still need help, you'll find contact information to reach our specially-trained representatives. Click the button below for your system and we'll walk you through the connection step-by-step.
    Apr 14, 2011 | Nintendo DSi Matte Blue Console
    I tried to contact the internet and it keep on saying your error code 051099 and i wanted internet
    Hi tabia tabz, Nintendo has an excellent walk-through on fixing just that issue. Instead of just re-ryping their information I will post it exactly as they had it because they offer very nice images of exactly what you need to do each step which should help you alot.
    Here is what Nintendo states:
    Error Code: 051099 Was this information helpful?Unable to use your wireless signal
    2. Trying to play online multiplayer with Nintendo DSi
      Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.Try this:
      1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
      2. Scroll over to the third page, and select "Internet."
      3. Now choose "Connection Settings."
      4. Click on "None" for "Connection 1."
      5. Click on "Search for an Access Point."
      6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network.
      7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
          unlocked.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_compatible.png WEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_wpa.png WPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
    3. Other suggestions:
    Feb 23, 2011 | Nintendo Dsi Pink Console
    I wont to change my router from nat type 3 to nap type to so i can play with my playstation 3 online can you please fine a solution
    Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
    Play Station
    Now go to the settings page of the PLAY STATION
    NETWORK SETTINGS ==>
    INTERNET CONNECTION SETTINGS ==>
    WIRELESS SETTINGS ==>
    If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
    select EASY ==>
    select WIRELESS ==>
    SCAN ==>
    you will see your SSID ( wireless network name)==>
    select the security settings ( router wireless settings)==>
    enter the KEY ==>
    select the IP address settings EASY ==>
    save your settings ==>
    Test the connection .
    Jan 10, 2011 | Zyxel (91-004-361002) Wireless Router
    I am attempting to set-up my daughter's x-box and it is asking me for a WPA pass phrase...where or how would i find it?
    May I have the brand name and model number of the router so that I can help you better.
    Thanks in advance!
    Regards,
    Prema
    Dec 29, 2010 | Computers & Internet
    My ps3 will not connect to play online
    Well, it could be one of a few things.
    On your computer in your network settings, ensure your network discovery is turned on.
    When you go to set it up on your PS3, make sure that you have all passwords required to get into your network.
    If you manually configure your settings, open your command prompt and type: ipconfig/all this will tell you all of your settings and IP addresses.
    If it's an older router, make sure it's within a 10-15ft range so the system can recognize it. If you need to get a new router, some will tell you to get a wireless G for gaming; I got a wireless N brand new (Belink) for $60 and it works way better than the wireless G one I had.
    If all else fails, reinstall your router on your computer and leave everything on default except for maybe a password to access the network. When you go into your PS3 settings, let it configure it automatically and just put the password in when prompted.
    Good luck and if I've helped you please give me a good rating.
    Respectfully,
    Don
    Mar 11, 2010 | Sony Playstation 3 (PS3) Console
    I have a PS3 in one room and my computer and internet in another. I have bought a wireless router but it is hooked up in the room with the computer. I don't want to have to run a cable to the other end of...
    Check your wireless network name in your computer if it is wireless enabled.
    Then go to your PS3. Go into the network settings and check if the wireless connection is detected.
    When you check the network settings, make sure that ip and dns settings are set to automatic.
    After that you would need to open some ports on the comp for your PS3 so that you can play online.
    Also let us know the make and model no of your router so that we could tell how to open the ports on the router GUI.
    Very first thing your PS3 should detect the wireless connection on it.
    Feb 21, 2010 | Sony Playstation 3 (PS3) Console
    I have a t mobile usb internet stick which i use to get my internet trhough my pc,and i have an ethernet cable that goes from the pc to my ps3 .everything works fine the internet connection on the ps3 is...
    Only router can give you proper NAT settings that can allow you to play online. Since you have a USB internet stick, try to buy a USB to Ethernet converter first. Then you can now use a router
    Jun 10, 2009 | NetGear WGR614 Wireless Router
    Problems finding online games with ps3 using BWA711 wirelessly
    My problem is the dropping connections with COD4. I can not play a whole session without losing it.
    I am about to give up and buy a new router.
    any suggestion?
    Feb 01, 2008 | Blitzz Technology BWA711 (B3WL000900)...
    Sony PlayStation Portable (PSP) Console Logo
    15 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
