Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television
Problem for Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television
SOUND, BUT NO PICTURE
By dwms8of8 on Nov 05, 2009
Solution #1
posted on Nov 08, 2009
Not Rated)
dah69
Rank: Guide
Rating: 0%, 0 votes
Believe it or not...I repaired my Westinghouse LTV-32w6 HD TV. it had no picture and just sound. I took the back part off, I took the stand off, and then I took the metal plates surrounding the main board and back light inverter off. I inspected the backlight inverter, saw nothing bad, inspected the main board, saw nothing bad, inspected the power supply, and saw nothing bad. What I did notice was the flimsy aluminum foil tape that I guess is supposed to ground the metal chassis around the TV. I did not see any other means of grounding except this. In my opinion, this was poor grounding. I went ahead and took the main board off; at this point there are a lot of connectors you have to disconnect. The good thing about these connectors is that they are all unique so you really can’t connect them back the wrong way. So, I found another smaller metal plate on the back of the LCD. I took off the plate and I found that there was a board with the numbers “V320B1-C” on it. This board had four connectors at the top and 1 at the bottom. (yours might be different) I noticed that there was a burnt spot on the lower right side of the board. By the way, this board is called the LCD controller board. I thought to myself, if I replace this board, it can be fixed. I went on EBAY and found used boards for under $50. I even found out that these boards are also used buy 32” Poloroid LCD TV’s. Anyways I ordered the board, installed it, and BAM! The board exploded! It blew up at the same place the other board had the bunrt spot. Damn I lost about $45. OK, I was not about to quit yet. I should have done more inspections. I inspected the 4 connectors at the top of the board. It has 4 short flat cable strips. I noticed that two of them had very small burnt spots on them. So I took the LCD itself apart (many more screws to take off) and inspected the thin side boards and didn’t find anything bad. So I put the LCD back together and went ahead and ordered the same board on EBAY. This time, before you order the “V320B1-C” board, MAKE SURE YOU ASK THE SELLER IF THE 4 UPPER FLAT CABLE STRIPS COME WITH IT, IF NOT ASK HIM TO INCLUDED IT. It might cost a bit more but it would be worth it. If the seller doesn’t have the strips, then don’t get the board; keep looking. ALSO, COMPARE THE EBAY PICTURE OF THE BOARD WITH YOUR BOARD AND MAKE SURE THEY LOOK IDENTICAL. Some boards will have the same model but will look different. After you get the board and the flat cable strips, do a quick inspection on the board and cables to see if you notice any burnt spots. Install the cable strips and board, then put the metal plate on top of it. Connect all the wires back together to the main board, speakers etc. Put everything back together, EXCEPT the back part. Last thing, you will need wire strippers, and a piece of wire (about 2 foot, 18 awg stranded and insulated, like thin speaker wire). Remember the aluminum foil tape that supposedly acts like a ground, you will make a better ground. Look at the bottom left edge, the screw that holds down the metal chassis (any screw that touches metal), loosen the screw, get the piece of wire and strip the end to expose the wire. Wrap the wire around the screw and tighten the screw. Now run the cable up and around the edge of the LCD, skip two screws, loosen another screw that holds metal chassis, and cut the cable and strip to expose the wire and wrap the wire around the screw, but before you tighten, get a second piece of cable, strip it and wrap around the same screw, and tighten. Repeat this process until you reach the bottom center part of the LCD. Connect the power and cable to it and cross your fingers. I was so happy when I saw the WESTINGHOUSE logo come up on the screen
Was this helpful?
Yes
No
Solution #2
posted on Nov 05, 2009
Not Rated)
budmrtn
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 155 votes
Look at the venting grills on the back to see if you can see any white lights inside, if no lights, then the backlight inverter may have gone out or it may not be getting the power from the main power supply section.
Was this helpful?
Yes
No
Popular Solutions for Westinghouse LTV-32w1 32 in.
Questions and Unsolved Problems for Westinghouse LTV-32w1 32 in.
Do you recommend Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television?
Answer
Answer
i have a Westinghouse 32'' HDTV model # W3223. recently when i turn it on the volume will... (More)
Answer
I have a tv model no LTV-20v2 SL type no SLT20A only have sound but not Imagen since last night
Answer
I have only colored lines, i can hear the sound but have lines
Answer
my television has colored lines going up and down the screen. i can hear the show just can't see it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Westinghouse LTV-32w1 32 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
