Nokia E51 Cellular Phone
Problem for Nokia E51 Cellular Phone
E51. when switched on, only shows Noika on white
By judy_mike on Nov 05, 2009
E51. when switched on, only shows Noika on white background, and will not respond. there is nothing else on the screen
Solution #1
posted on Nov 11, 2009
Not Rated)
chinmay_pat
Rank: Guru
Rating: 90%, 22 votes
This generally happens if you are using a hign volume SD card such as a 4 GB one and have a lot of files there. Then nokia when booted may try to scan all those files and takes a lot of time.
Remove your SD card and move most of insignificant data onto your computer using a card reader or the nokia usb cable. Then put the elmost-emptied SD card in your cel phone and try to reboot the phone.
Hope this helps.
Otherwise visit a authorized nokia service centre, they will upgrade the nokia's system.software and will fix application problems if any.
Was this helpful?
Yes
No
Popular Solutions for Nokia E51 Cellular Phone
Questions and Unsolved Problems for Nokia E51 Cellular Phone
Do you recommend Nokia E51 Cellular Phone?
Answer
Answer
my nokia E51 connects to my Eclipse CD7200 mkII then instantly disconects, why and how can I fix it?
Answer
Help!I dropped my phone, I can switch it on but I can`t key in my pin...the number pads don`t... (More)
Answer
My phone nokia e51 is on but dont work any key
Answer
phone continually hangs when i press the menu button. i have to turn the phone off and back on to... (More)
Answer
animated theme and wallpaper for e51 does not work
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia E51 Cellular Phone:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
