Question about Palm Tungsten E2 Handheld
Won't shut down
My Plam E2 restarts itself whenever I attempt to turn it off. In addition it is not automatically timing out and shutting down at the designated time of 2 minutes. My battery is constantly being depleted.
  • bradcx12 Jan 07, 2008
    I've done a hard reset and the Palm would power off and stay off until we performed a hotsync. After the sync, the problem would be right back. We are running Vista OS.
  • 59 Answers
There are a couple of things you can try.
1- Poke the hole in the back where it says reset.
This will in essence reboot your Palm.
2- Make sure the Auto-Off after: is set to 2 minutes by going into the Preferences, Power section.
3- If your Palm is not holding charge, connect the Palm to charge it. Turn the Palm on and make sure the battery at the top has a lightning bolt going through it. This will let you know it is charging. Then, push the reset hole in the back to reset the Palm. This should reset the charging mechanism in the Palm and allow your battery to hold power.
If the Palm does not hold power after step 3, you may need to see about getting it serviced.
Posted on Jan 04, 2008
6ya staff
SOURCE:
Shutting itself down
Make sure the charger is plugged in before attempting this. If already plugged in or same thing happens then you can try and follow the guide as below to do a hard reset:
http://www.mobicpc.com/how-to-hard-reset-archos-97-titanium-hd-to-factory-default-setting.html
If still not able to reset, poss hardware issue
Thanks
Oct 23, 2013 | Archos 97 Titanium HD 9.7" IPS Tablet
Where is fuel shut off valve on f150 2009
I own a 2009 F-150, & the owners manual included this information; "In the event of a moderate to severe collision, this vehicle is equipped w/ a fuel pump shut-off feature that stops the flow of the fuel to the engine. Not every impact will cause a shut-off. Should your vehicle shut off after a collision due to this feature, you may restart your vehicle by doing the following; 1. Turn the ignition switch to the off position. 2. Turn the ignition to the on position. In some instances the vehicle may not restart the first time you try to restart & may take one additional attempt." I scoured the manual, & there is no mention of a "switch" anywhere, that it is an automatic system. probably too late to help, but there it is.
Sep 22, 2013 | 2009 Ford F-150
My problem with my phone is that everytime I turn it on it just automatically shuts down by itself (without me pressing the TURN OFF/ON button).. Whenever also if it's off, it just turns on by itself.....
hi:) i think your phone software has been crack,mad eit automaticaly on and off. i suggest u do a reload software buy your self or send for nearby mobile shop.
pls voted me if my solution useful,thank..
Aug 02, 2010 | Nokia 6070 Cellular Phone
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
When i restart the system don't turn on again
something may be wrong with the power supply. i have a computer where the power supply is faulty and it used to shut down automatically after 1 hour. nowadays, it shuts down more frequently, whenever restarted, it will not come up again. i have to wait for sometime so that power-supply can cool down and i can start. -Nitesh Kumar Anand
Apr 16, 2010 | Mercury P4VM800M7 Motherboard
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
Turns on and off automatically
getting hot and shutting down try to clean it out could be very dusty inside
Jun 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Palm Tungsten E2 Handheld Logo
124 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
