Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Hotpoint sy51x oven
Hi can someone help me i have a hotpoint sy51x oven .it does not heat up like it used to .i put it on full heat where it would normally take about 10-15 mins it is now taking about 50 mins if not longer .can somebody tell me what the problem is with it
    Sergeant:
  • 264 Answers
Your thermostat is on its way out it is place on the other side of the knob you will need a oven engineer to have a look
Posted on Jan 05, 2008
Need to take a photo of oven selector on a Hotpoint SY51X single oven please.
Use a digital camera or just Google search for an image
Aug 04, 2016 | Hotpoint Ovens
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
My hotpoint single oven wont heat up.the light will only go on when i turn to knob to light on..but it doesnt come on when i turn the knob for oven on and it doesnt heat up...until yesterday it was working...
Hi there If everything else is working then it's probably the heating element They are not expensive to replace and can be fixed in less than an hr Hope this helps
Sep 25, 2013 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
Why is my Hotpoint EW73 oven not reaching full temperature>
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 21, 2010 | Ovens
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
Hotpoint UD47 electric oven not hot enough
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Ovens
Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Nov 24, 2009 | Ovens
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
350 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
