Question about Rio Carbon MP3 Player
SRS light on and will not go off
2003 Mits. Eclipse. The SRS light will not go off. Dont have money to take it to the dealership. What do I need to do? What will happen if its not fixed?
    Guru:
  • 155 Answers
Wrong section for post
Posted on May 15, 2008
Why Would srs light stay on in a mitsubishi Eclipse 2003 model!
SRS means secondary restraint system - air bags. If the light remains on, it means the the air bag module has detected a problem with your air bag system. Have codes read (you'll need a reader that can read codes from the air bag module) to see what the problem is, and have it repaired. Best left to a dealer or shop that has experience with air bag systems.
Apr 11, 2017 | Mitsubishi Cars & Trucks
2003 mits eclipse automatic does not shift into gear. shifter works but no engagement, no reverse, drive
Check that the shifter cable is fully moving/engaging the linkage on trans other than that check fluid and check electronic plug connection
Jan 05, 2013 | 2003 Mitsubishi Eclipse Spyder GT
My mercedez benz 2002 c240 has the srs light on the dash board what does it meen?
I have C240 4matic 2003 the SRS light On so that's mean and how much cost and there's things can I do before take it to dealership????
Jun 13, 2012 | Cars & Trucks
Help, I have a mitsubishi 2004 lancer and a SRS red light keeps coming on, what is this and what should I do.
SRS IS SUPPLEMENTAL RESTRAINT SYSTEM. THIS IS YOUR AIRBAG SYSTEM.WHEN YOU SEE SRS LIGHT FLASHING TAKE VECHICLE TO DEALERSHIP SEE WHAT CAUSING PROBLEM DONT TRY FIX AIRBAGS SYSTEM YOUR SELF LET DEALERSHIP FIX AIRBAGS DANGEROUS THEY CAN DEPLOY WHILE TRYING TO FIX SO LET PROFESSIONAL TECHNICIAN FIX.
Nov 05, 2011 | 2004 Mitsubishi Lancer
Airbag light goes on checked all fuses are not
SRS SYSTEM HAS A FAULT , THIS COULD MEAN MANY THING
INPORANT TO KNOW SRS DOES A SELF CHECK EVERYTIME YOU START YOU VEHICLE , THIS LETS YOU KNOW IF THE SYSTEM IS WORKING OR NOT.
IT LOOKS AS IF YOU HAVE A FAULT WITH A PART OF THE SRS CIRCUIT.
PLEASE DO NOT TRY TO FIX , COULD BE DANGEROUS!!!
YOU NEED TO TAKE IT TO YOUR LOCAL DEALER.
THEY WILL SCAN SYSTEM.
AFTERMARKET GARAGES DONT HAVE AXCESS TO THE SRS SYSTEM.
THERE COULD BE A SHORT OR OPEN IN CIRCUIT.
I HOPE THIS HELPS
Apr 29, 2010 | 2003 Toyota Corolla
I need to remove and replace the Radio in 2003 mitsubishi eclipse
I WOULD LET THE DEALERSHIP REPLACE RADIO BECAUSE BY IT BEING PART OF THEFT SECURITY SYSTEM.IF YOU DO IT YOUR SELF YOU PROBABLY GOING TO HAVE NO START PROBLEMS.THE PCM WILL GO IN THEFT MODE THINKING SOMEBODY TRYING TO STEAL RADIO OR CAR.IF DEALERSHIP FIX THEY PUT IN NEW RADIO THEN REPROGRAM IT.
Mar 31, 2010 | 2003 Mitsubishi Eclipse Coupe
Need help locating drain tube on 2003 mits eclipse
Look down the firewall on the drivers side, right behind the throttle body area.
About 18" down there is the end of the firewall insulation, fold it up and back and behind it you will see the drain tube (about 3/4") sticking through the firewall just above the steering rack.
Sep 13, 2009 | 2003 Mitsubishi Eclipse Coupe
Where are the spark plugs located on a 2003 Mits. eclipse 4cyl gs
the spark plugs are in the top of the engine going thru the valve cover into the cylinder head. you might have a plastic cover that is over top of the valve cover which is covering up the spark plugs. they are very easy to change out.
Aug 10, 2009 | 2003 Mitsubishi Eclipse Coupe
Srs light is on
Weak power from alternator.
Use a volt meter and check for the voltage.
It should be 13.8V to 14.2V
Here's a quick check list for most common cost of SRS / Air bag problem.
Dirty contacts on driver and passenger seat belt buckles
Dirty contacts on seat belt connectors (under seats)
Dirty contacts on driver and passenger sides weight sensors (under seat)
Seat covers
Weight on passenger seat
(Example: grocery package trigger SRS / Air Bag light on the way home.)
I recommend you to pass an vacuum over the contacts and use CRC electronic parts cleaner to rule out connectivity problem.
I DO NOT recommend disconnecting the negative battery connector to clean the code(s).
Without the code(s) the dealer will takes "BILLABLE" time to reproduce the problem.
Please rate my answer if it is useful to you.
Cheers,
Mustgo
May 18, 2009 | 2003 Mitsubishi Eclipse Spyder
Dealership Closed
call mitsu cust, service - the dealer has to take the car in!
Nov 24, 2008 | 2006 Mitsubishi Eclipse
Rio Carbon MP3 Player Logo
177 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
