Mag Innovision LT782S  17 in. Flat Panel LCD Monitor
Cleaning monitor
posted by dazzyd56 on Jan 04, 2008
I just need to know how to clean my new monitor. Do I use window cleaner?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 04, 2008
Helpful (85)
tom19511
Rank:Guru Guru
Rating: 85%, 1800 votes
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cleaning monitor:
I don't want to Accept this solution
Solution #2
posted on Jul 21, 2008
Not Rated (0)
nssms
Rank:Wiz Wiz
Rating: 85%, 15 votes
HP recommends not to use alcohol based cleaners on their flat pannel monitors.
Thank You!
Solution #3
Not Rated (0)
sir fixalot
Rank:Guru Guru
Rating: 91%, 139 votes
you can use window cleaner but apply the cleaner to a rag do not spray it onto the monitor.
Newspaper works very well and leaves no streaks.
Thank You!
Can you Help with these Monitors problems?
Mag Innovision LT782S (Black, Silver) 17...
Is my monitor dead???
The monitor will not power up. When plugged into power it...
I have a MAG innovations LT782s 17 " monitor. My old...
For about a week, my monitor took about half an hour of...
My speakers are built into the monitor, but I have no...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
