Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | Condensor unit fre...
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Condensor unit freezes up.What would be the best
By gwbdmanny on Nov 04, 2009
condensor unit freezes up.What would be the best way to cean unit without taking it out
Clarification Request
Posted by housejess on Nov 04, 2009
pay professional or lowes has a coil cleaner..never use a power washer....is your filter inside the house new if its dirty it could cause this........fan motor on uniy outside could be bad
Best Solution
posted on Nov 05, 2009
Very Helpful)
mac5932002
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 52 votes
unfortianatly without removing it your really not doing yourself any favors, it may stop freezing up for a short time but its only a half @#* fix. i am also assuming your speaking of the evaporator not the condensor, the condensor is outside the evap is inside
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
when this happens i open up the unit outside & there is only one test light flassing. i have to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
