Home | Keurig | B60 Coffee Maker | Coffee maker is not pum...
Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
Coffee maker is not pumping water fast enough.
By sandyweigle on Nov 04, 2009
coffee maker is not pumping water fast enough. takes over
a minute to brew a 8 oz. cup. pumps water real slow.
Solution #1
posted on Nov 04, 2009
Not Rated)
anil8tor
Rank: Guide
Rating: 100%, 2 votes
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
I use 2 Keurig B40's for my display and I need to replace my broken water compartments... please... (More)
Answer
1 yr old b60 model all of a sudden will not brew after it has drawn extra water from the resevoir... (More)
Answer
the information center says "not ready" no matter what I do
Answer
just bout keurig single serve, it made one cup now it won't make another one
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keurig B60 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 897
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
