Question about GE DCSR483EA Electric Dryer
GE Dryer My GE dryer is 2.5 year old and for the last year or so, the dryer will run for about a quater of the cycle (heating and all). Then it will just cut off for no apparent reason. The lint trap has always been clear and clean so I'm not really sure what's wrong. Any ideas?
  • 283 Answers
Sounds like an intermittant break in the heat element. Could also be an irratic control thermostat or bad connection somewhere between the line and the heater. Simple to isolate with a tester.
Posted on Jan 04, 2008
GE dryer runs but only heats on timed cycle not the other 2 cycles.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 17, 2015 | GE Dryers
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Dec 21, 2008 | Dryers
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
GE DCSR483EA Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
