The panel works and the timer counts down when I turn it on, but it doesn't microwave anything. I...
(More)
The panel works and the timer counts down when I turn it on, but it doesn't microwave anything. I flipped the breaker and it didn't help. That is about the extent of what I know about microwaves. The manual sucks or else I would also check the fuse. Thank you for any help available.
hi Expert, I have a frigidaire fmv145bc1 microwave. It seems to be frozen in a functions. Symptom:...
(More)
hi Expert, I have a frigidaire fmv145bc1 microwave. It seems to be frozen in a functions. Symptom: start cooking food, I interrupt the cooking by opening the door or pressing stop. I close the door and the led tells me to "press start" to continue cooking. Now all buttons will not work except for clock button interupts the "press start" message but as soon as you release the clock button the "start message comes back. Also the fan, light, and delay start work but delay will not start as I can not get the start button to work. I unplug the microwave and all is good until I interupt the function again. Any Ideas from my discription what part of the circuit board need repair??? Thanks for you help, George
microwave model-fmv145ks1 every thing works but does not heat. I would like to know if it is an easy...
(More)
microwave model-fmv145ks1 every thing works but does not heat. I would like to know if it is an easy fix or if it worth the trouble. its a above range type.
