Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Hd format How do I format a 200gb hard drive? thanks mac
  • mac do Jan 06, 2008
    suisboy,
    Ty, I tried opening my other newer computer but noticed that the bus has different number of pin. I tried the connector to the dvd but the computer recognized it as an audio hardware. Actually this 200gb hard drive work on my old computer if run on safe mode but freezes on normal mode, I tried to reformat the hard drive then try to load all the software but I always get an error message. For trying to restart and solve the problem several times, now I cant even open the computer even on the safe mode menu. Any more advise?
    thanks again
    mac
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well how you want to format it?
just connect it to a system which have a operating system installed.
right click on the drive and select format.
select the options and click format it will format the drive.
Posted on Jan 06, 2008
  • Anonymous Jan 07, 2008
    what was the error Message did You get?
6ya staff
SOURCE:
I have 2 Hitachi 3 TB External USB Drive External Hard Disks that are not recognized by my Mac OS X 10.6.8. Have I bought the wrong ones?
have you formated your hard drives? are your black or white jumpers hooked to the pins on top of hard drive? if the hard drives are new chances are the jumpers are still in small plastic package.the jumpers are little peaces of plastic with two holes with metal in them. the jumpers go on were it says master if you are using 2 hard drives .the other hard drive the jumper goes were it says slave. if you are using 1 hard drive you put the jumper on cs.
Sep 23, 2013 | Hitachi 200GB External USB Drive 200 GB...
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
How to transfer 57 gigs from a mac to firelite xp.
The hard drive maybe formatted in Windows NTFS format and the MAC cannot see this formatted hard drive.
If you only wanr to use this hard drive on a MAN then you need to format this hard drive with your MAC.
If you want to exchange files between your MAC and a PC then you need to format the hard drive on a PC in FAT32. The MAC can read and write to a FAT32 formatted hard disk.
May 30, 2012 | SmartDisk FireLite 80 GB Hard Drive
Hey my Buffolo harddrive wont show my files, i can see that there are files, i have used 180 out of 200GB, but when i click on my harddrive icone on my computer it sayd folder is empty.. PLEASE HELP
There are generally 2 formats for Hard drives, the NTFS for windows and the FAT 32 for MAC. If you previously used windows then mac wont see it and vice versa. You can check this by right clicking and see the properties. If you want Mac to back up as well as using it on windows, you need to partition the Hard disk by going into the Mac Applications folder then select Utilities. If the Hard drive is connected you should see it and can select erase from the menu tab to format the disks according to your needs. This solved my problems and I hope this helps.
Apr 10, 2011 | Buffalo Technology DriveStation HD-HC500U2...
I have an external hardware maxtor 200GB, previously for mac., how to use it for PC?
FORMAT AND CONNECT TO PC IF NOT RECOGNIZED MAY BE BAD HARD DRIVE . OR NOT COMPATIBLE
Nov 23, 2010 | Maxtor OneTouch II external hard drive...
200gb drive registers as 2000gb when I try to format
why not either rename this drive at the correct size or format and partion etc,
If the drive shows 2000GB then why not put some stuff on it say 300GB and if its a 200GB it will give you a FULL message once it reaches 200GB
May 27, 2010 | Western Digital (WD2000BB) 200 GB Hard...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Loosing 2gb on hard drive everytime
if it has hp windows installed as standard it reserves some space for recovery so if O/S plays up it can be recovered from it.
One other thing it may be is if a hard drive is listed as 200gb when formatted it is a lot smaller
listed size 200gb formatted size 185GB this is only an example as actual size may differ hope this helps
Jul 24, 2008 | HP Pavilion dv6000z Notebook
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
288 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
