Question about HP DeskJet 500c InkJet Printer
21:10 error When I turn on the plotter, it runs through it's start up routine and stops with a system error 21:10 Any ideas?
  • HotRoddy Jan 05, 2008
    Robosoft,
    Thanks so much for your help.
    Successfully operating now!
    I hope your there next time I fall down.
    HotRoddy
  • 22 Answers
Hi HotRoddy,
This is a Service station error. Check for obstructions in the service station on the right.
Turn on the printer in service mode by holding down the UP arrow and ENTER keys (simultaniously).
Enter Service Utilities, choose Unlock Carriage. Turn the printer off and move the carriage to
the center of the printer. Turn the printer back on. The carriage and service station should
return to their home positions.
If the error returns on power-on, the service station will probably need to be replaced.
Parts and diagrams can be found at partsurfer.hp.com.
Hope this post was usefull for you.
Thanks,
Robosoft.
Posted on Jan 05, 2008
Maytag dryer MD-24 error symbol?
The dryer completes the cycle you have set. If you do not remove the contents at the end of the cycle, the dryer performs the start-stop routine you describe until you get around to removing the contents. Eventually even the start-stop routine ends and the contents just lie in a heap until removed
Mar 11, 2013 | Dryers
Hp designjet 800 error code 21.10 plotter runs trhogu the start up and stops with a System Error code 21.10
This is a service station error or failure. You will need to replace it, actually a easy job.
Aug 09, 2011 | HP DeskJet 500c InkJet Printer
What is the error 42:10? I keep getting this error and sometimes error 86:01, please help. When I start plotting a map or in this case early this morning on my first map I got this error 42:10, so I turned...
42:10 is carriage motor error, 86:01 is carriage jam. Check slider rods (both upper and lower) and carriage oil pads are lubricated, clean encoder strip. Is your printer is shaking too much? Place it firmly.
Feb 08, 2011 | HP Designjet Z6100 InkJet Printer
Hi, we have a roland camm-1 cutter plotter. It has been showing "fan error" on the display these last few days but would correct itself when turned off and on again. Now though,when I put vinyl in and send...
I had a similar problem. The issue was that I would receive a "fan error" notice but the fan was still spinning when the error displayed and then the machine would stop. I took plotter to my garage, removed the covers and used my air compressor to blow out the dust from the fan and the circuit boards. When I blew out the fan, a ton of dust and "dots" from the punched material came flying out. After a thorough cleaning, I put it back together and have not had the problem since - it works like new. I think what happens is that the fan becomes clogged with dust and dots and slows the fan enough to send an error signal to the plotter. No dust, no dots, no error! Try that - hope it works for you!
Sep 16, 2010 | Computers & Internet
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
How do I stop the plotter from going into the printhead check routine and wasting ink and media every time I turn the power on?
dont turn it of .if the machine is not used for a while it will go into powersave mode.if the machine is turned off it would have to prime the heads when turned on to ensure good print quality
Oct 28, 2009 | HP DesignJet 1050c InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
HP DeskJet 500c InkJet Printer Logo
1,123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
