Question about TruTech PLV1615T 15 in. LCD Television
No pix plug in the cord white pix appears ... no pix no sound front controls do nothing fusre ok shorted
  • Anonymous Feb 28, 2008
    Plug in TV, White Screen,Buttons do not work on front. TV has barely been used.
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Posted on May 21, 2008
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
Jan 20, 2013 | LG 42LC7D-UB Television
Every time i try to turn my hotpoint wt960 washing machine on it blows the main fuse i have changed the fuse in the plug and tried a diffrent socket
Sounds like you have eliminated a few possible sources of the problem, but we have to dig deeper--
Do you have some way of checking for shorts and continuity?-- Like an Ohm meter?- or a continuity checker?
YOu will need to remove the control panel, and check for a short either on the cord, or inside the control panel.
Inside the panel, the 3 wires from the power cord, attach-- Can you see the Green and then the WHite and black leads?
With the Plug out of the wall, You should get infinite ohms between the White wire and ground, as well as the Black wire and ground-- A low ohms reading indicates a short to ground-- Now we have to find that short.
Can you trace the circuit thru from Black wire, thru the controls, back to the white wire-- and can you check for shorts at points along the way?
Let me know what you find, and we'll help you further.
Mack B
Jan 16, 2011 | Fisher and Paykel (IWL12)
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
K5ss no power tested cord-ok inside all wires (red blue etc.) test ok. white on lower right hand side shows nothing on meter.
It sounds like you need a new speed control phase board:
Jan 18, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Turned TV on with remote, circular indicator went
Please call Memorex customer service at 800-919-3647.
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If the TV is less than one year from the date of purchase, it is still under warranty. Call the number above so that you can have the unit repaired.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 17, 2009 | Memorex MLTD2622 26 in. LCD TV
Can't upload pix
when u turn on the camera is the view finder black?
Sep 05, 2008 | Nikon COOLPIX L4 Digital Camera
Disney Pix Max 3.0 Megapixel Camera by Digital Blue can't download photos
If you're plugging the camera into a port on the front of your computer try one of the ports on the back. The front ports in most cases only provide 100 milli-amps of power whereas the back ports provide the full 500 milli-amps of power. This could be the problem or it could be your USB cable. Try a different cable and see if that makes a difference. Just make sure that you aren't plugging it into a USB hub and you're connecting it directly to a port in your computer.
Mar 05, 2008 | Disney Pix Max Digital Camera
Well let see if we can talk you thu "grayscaling " a set, first remove the speaker grill and the front cover to expose the screen/focus controls these will be six controls mounted on a plastic looking box, next turn the set on and get a good signal, Then from the custmer menu simpley go the the pix settings and turn the color all the way down, next use the screen controls to make the pix the best black and white you can. Next turn to a input that has no signal and the pix should be black, if there are small retrace lines simply turn down that color till it goes away , then back to a signal source that should still have a good black and white pix. Put everything back together and turn the color back up
Feb 07, 2008 | Toshiba TP55H60 55" Rear Projection...
TruTech PLV1615T 15 in. LCD Television Logo
43 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
