Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
I have a Maytag Neptune stacked W/D unit. Won't spin. Problem is definitely 1 of 2 switches (inertial imbalance/upper tub displacement), both of which are NOT accessable through the front or back panel of the machine. I know where the switches are located within the machine as I have the spec sheet for the unit. The problem is I can only find instructions for a stand alone washer - not a stacked unit. It requires that the top cover be removed. Being that the dryer is sitting directly on top of the washer, (all washer/dryer control knobs/buttons sit above the washer/are part of the dryer portion of the unit) I can't remove the top cover of the machine. It seems to me that the only way to get to the parts I need to replace will be by somehow moving the dryer at least partially off of the washer, but I'm not sure if its okay to do that or even whether its possible. All I know is that there has to be some way to get to the switches to replace them - can you advise? Is there a separate manual or instruction for stacked units? This has to be doable . . .
My Model # on the washer is MHS2000AWW, which no one seems to be able to find but it looks just like Model # MLG2000A, which is I think a later model.
Thanks, Melinda
  • 2 more comments
  • Melinda Fabrikant Jan 15, 2008
    Boy. Thanks for your reply! I am getting desperate here . . .
    Well, the control board shows no sign of damage and the door lock mechanism works fine when the machine is set to cycle 3. And I tested the switch in the door lock assembly but still no spin. I don't have an ohm meter so I used a paper clip to jump out the switches. Then I did the same with P3 pin 1/P2 pin 4 on the control board, ran the machine in cycle three and it spun, so I think this should indicate a balance switch problem, no? I don't think those switches can be reset, can they? Anyway, I replaced the lower tub displacement switch at the front, bottom of the machine since it was easiest to get to, but still no spin so I assume now it must be the upper displacement or inertial imbalance switch that's bad.
    I bought the repair manual and removed the washer front and door boot. This let me see and feel the upper tub displacement switch, but I can't quite get to it and I still can't even see the inertial imbalance switch. I think the only way to get to them is through the top of the machine by removing the dryer or at least shifting it to one side. I've disconnected the electrical connectors to the washer so no worry re: that issue. Ironically, the repair manual says nothing about how to remove the dryer/just gives a hard to see exploded view of components for each unit. On visual inspection, it looks like the dryer is clipped into the washer in front (not screwed directly through the washer frame) and there is a bridge/straight bracket fastening each end of the dryer to the washer in the back. I can't see if there are screws fastening the bottom of the dryer to the washer at the back of the dryer. Do you think I can just remove the back brackets/front clips and slide the dryer over or back enough to get to the switches???
    Does any of this sound right to you?
  • Melinda Fabrikant Jan 21, 2008
    Okay - final report - I did get the dryer up off of the washer (actually really easy as in the end all it took was removing 4 screws, sliding it forward an inch and tilting it up balanced on its back edge). As soon as I looked down, there was the inertial displacement switch with one of the feed prongs snapped off!!!! I replaced the switch and the machine is now working like a charm/spinning like a top. I am feeling really good about being able to fix it myself with lots of online help! Thanks so much for your input!
    Actually in my final report, I meant to say "there was the inertial imbalance switch with one of the feed prongs snapped off" - not inertial displacement switch - sorry if I confused anyone . . .
  • rcmsr Jun 19, 2008
    my nepyune wont spin out fully i have replaced both boards, but still the sme problem will start to spin but then slows and stops if it is the inertia imbalance switch where is it located on a stand alone washer thanks for the help
I have a neptune mlg2000aww that has the same problem. had a service guy come out to check it out. he charged me $50 to tell me it would cost $360 to replace machine control board. I called an appliance parts supplier and found the MCB for $170. It took me approx. 20 - 30 min. to replace. Turned the washer on and voila it still didn't work. so thanks for posting now i have new found hope for my washer and peace of mind not to mention clean clothes in the near future.
Posted on Feb 05, 2010
  • 196 Answers
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Posted on Jan 15, 2008
  • Elmer Vest
    Elmer Vest Jan 15, 2008
    A set-reset switch is the same as a push button. It works by itself. I understand now why you suspect the switches
    There should be two screws (maybe more) holding the bracket on the back. Take the screw out and the should slide foward to release the clips.
    The problem could still be in the Machine Control Board but I'm leaning more toward the timer. The timer is nothing more than a series of relay contacts than run on cams. If the contacts are faulty or there is a bad cam then the machine will not work in whatever modes are involved.
    I hope you solution is correct because mine can be expensive.
    Please let me know what you find. I'm really interested.
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptun tub doesnt spin during spin cycle
The spin enable switch located on the door lock assembly is the most suspect failed part. Sometimes there are one or more sensors connected to the out of balance circuit that can cause a no spin condition. Lastly if your serial number qualifies, you will need a motor conversion kit as this failure can cause a no spin issue. Pleazer Appliance...
Nov 09, 2013 | Neptune MLE2000A Front Load Stacked Washer...
Maytag washer does not spin
What is the complete model number of your unit?
Dec 07, 2012 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
1,472 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
