Question about Proview HX303 30 in. HD-Ready LCD Television
Proview MA-32EF1AC TV won't turn on. I have a TV that the power LED goes form red to blue when it is turned on and then right back to red again. When I expose the circuit board in the back the power supply board resonates and a low frequency and one of the labeled supply output is a little low. Is it possible that the PS board is bad?
  • 1 more comment
  • John Fortier Jan 04, 2008
    One of the funny things about this problem is that I disconnected the cable and connected my laptop to it to see if I could get some type of display which I was able to. So I then disconnected the laptop and reconnected the cable and the TV worked again for a couple of days and now is down again. Would you change your opinion with this information or do you still think that is the PS board?
  • Anonymous Mar 23, 2014
    TV will not power on, it worked just fine last night. Any suggestions?
    TV will not power on, worked fine last night. Any suggestions?
  • 689 Answers
Power Unit might have some symtoms, But I believe cause might be on the main circuit. If power had totally failed It wouldnt give any output. Most of the swithching power units have overload protection. So if there is a component takes high current it stops providing the current. In order to check the power supply you can unplug the connection to main circuit and test with multimeter. For this case a qualified hands on technician's assistance unavoidable. As circuit should be diagnosed what is the cause of the issue. Especially Power Transistors (MOSFETS) should be checked.
Good Luck
Posted on Jan 04, 2008
    Genius:
  • 1,030 Answers
Although resonace does not always indicate power problems that would be the first choice.. i would say 80 percent chance that the power board is bad.. but theres always a chance that one of the other boards or even the panel could be loading the psu down
I have a MAG MA-32EF1AC TV that will not turn on and no longer has power - there is no light, red or otherwise showing on the TV.
hello make sure the socket yourusing is working ok, you may have a blown fuse in the plug, if ok you may have a blown fuse in the tv thanks
shaun
Feb 15, 2017 | Televison & Video
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Mag LCD TV MA-32EF1AC has power but won't turn on with remote or with power button on side of tv screen
If neither the remote nor the tv power button has any effect then it is safe to say that you may have an issue with the power supply section of your set.
Jun 22, 2016 | Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
I have a MAG, model 3200, product number MA - 32EF1AC. The red light is on, but when the power button is hit, nothing happens. What should I do?
maybe give it time..is it a smart tv?....might want to unplug and wait a bit, and try it again, if its a smart tv they like turn off all by them selves
Aug 12, 2013 | Televison & Video
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
LCD Tv MA-32EF1AC won't turn on
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 26, 2017 | Proview HX303 30 in. HD-Ready LCD...
Proview HX303 30 in. HD-Ready LCD Television Logo
465 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
archetrix
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
