Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001  CD-ROM Drive
Compaq Presario 1245
shared by 2 users
posted by Pj2008 on Jan 04, 2008
I have a I have a Compaq Presario 1245 laptop which doesn't start up. I haven't used it for two years, it was serviced before I put it away.
When I plug in the AC and switch it on a light comes up recognizing the AC pwer but it doesn't start, it makes a noise as if it's booting up but nothing comes up on the screen and it continues making the boot up sounds. I have replaced the Lithium CMOS cell inside hoping that would cure the problem but still the same, nothing has happenedI. Should I get a new battery. laptop which doesn't start up. I haven't used it for two years, it was serviced before I put it away.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Feb 15, 2008
i have a compaq presario which when pluged on the A/C it makes the boot noise but does not display on the monitor when i pluged it in to the desk top crt monitor it desplayed so i realiised that the desplay monitor for the laptop is dead so where do i get another monitor
send reply to Email adress (tabuleor@yahoo.com)
thanks
yours
Robert
Best Solution
posted on Jan 08, 2008
Helpful (85)
teglmh
Rank:Wiz Wiz
Rating: 82%, 94 votes
you could try booting on battery instead of mains and see what happens, also could the screen be switched off ? If you have access to another monitor, you could try plugging it in to see if the video output is ok. ( some laptops have a facility to switch off the screen display for security etc )
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Compaq Presario 1245:
I don't want to Accept this solution
Can you Help with these CD ROM Drives problems?
Compaq Presario 900 /1500 Series EVO n1015v...
need to figure out how to get the case apart so I can...
i am trying to order a power cord for the lowest price and...
Hi im Tim and ia have a problem on my Compaq Presario...
i just reinstalled vista to xp and now my speakers wunt...
i have toshiba labtop when i turn on everything processing...
Loading problems.
Repair Service
Find CD ROM Drive Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
