possible cause is faulty door latch also check latch on door for any raised or damaged surfaces next try pushing on door slightly if it latches and starts most likely door problem look more closely hope this helps
during washing it stops and sd appears on the estimated time left, then it starts again and then at...
(More)
during washing it stops and sd appears on the estimated time left, then it starts again and then at the end says sd again, till I take the clothes out
LP Front Load Washing Machine leaking a lot of water during use from the lower part of machine. It...
(More)
LP Front Load Washing Machine leaking a lot of water during use from the lower part of machine. It will leak soapy water and clean water. What could it be?
