Washing Machines
Generic problem for all Washing Machines
Water leaking from bottom of machine
shared by 6 users
posted by bobal1 on Jan 04, 2008
Water leaks out of bottom only on rinse cycle. Checked all hose connections and they are tight.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Posted by kengeorge on Jul 13, 2008
In rinse cycle when water starts to be pumped out a leak starts. It appears to be from the small bore plastic corrugated hose that attaches to the rubber belows behind the pump. and terminates by the filter.
Posted by Alora on Apr 02, 2008
I have a Whirlpool Duet front loading washer, approx 4 yrs old. It started making loud noise (drum off center), something is coming off and getting in with the clothes (looks like a large gasket or washer) and it leaks. So I called a repairman. Seems I need a new boot, problem with bearings (warranty) and need a new counterweight for $590. I told him forget it, because the washer was only around $800 brand new. Am now looking at a Maytag front loading washer. Good luck!
Posted by arle on Apr 02, 2008
I HAVE A WHIRLPOOL WASHER MODEL # LSQ9544K AND IT IS LEAKING WATER FROM THE BOTTOM OF MACHINE. NO PROBLEM WITH HOSES.
Posted by dweaver on Mar 30, 2008
I am having the same problem. It is more like pouring instead of leaking.
Posted by Guest on Jan 05, 2008
TAWK700JQ1 - Ours is leaking too.
Solution #1
posted on Jan 04, 2008
Not Rated (0)
sagacious
Rank:Guru Guru
Rating: 88%, 147 votes
Question is too broad. We need to know the brand and model.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on water leaking from bottom of machine:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Electrolux EW1000i Front Load Washer
I have an old washing machine - Electrolux EW 845F. Need...
GE Spacemaker Washer and Dryer Electric...
in repairing something with the washer unit of my ge...
Washing Machines
my machine is not storing water ,once program start...
Washing Machines
kenmore wash heavy duty 70 does not go into the spin mode...
Maytag Performa PAV2200
The timed dry cycle also quit working at the same time.
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
