Bosch Nexxt  700 Series WFMC6401UC Front Load Washer
Problem for Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
It wont unlock after giving me the f04 code...
By jdhgutn on Nov 04, 2009
it wont unlock after giving me the f04 code... cause it has water in it but i need to open it! it also the drum wont spin
Solution #1
posted on Nov 05, 2009
Not Rated)
mandlapplian
Rank: Guru  Washers & Dryers  Expert
Rating: 95%, 26 votes
sounds like your water pump has failed or blocked position your drain hose on the floor into a bucket or floor waste let water drain out you should be able to open door reposition drain hose in original position and try again if drain pump does not work check for blockage or replace faulty pump good luck
Was this helpful?
Yes
No
Popular Solutions for Bosch Nexxt 700 Series
Questions and Unsolved Problems for Bosch Nexxt 700 Series
Do you recommend Bosch Nexxt 700 Series WFMC6401UC Front Load Washer?
Answer
Answer
how do get the front off of a bosch nexxt dryer?I have taken all the screws that i can find out on... (More)
Answer
My machine is leaking from the left bottom..just started today. Not sure what the problem... (More)
Answer
Bosch washing machine WAE 24162 washes continuously and has to be advanced manually via the buttons... (More)
Answer
I need something to make my old towels soft, i have tried loads of fabric softners, even vinegar but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch Nexxt 700 Series...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
