If it requires the choke to run it is running lean. Continued operation in a lean condition will cause piston & cylinder failure. Determinr why it is suddenly running lean.
If you did nothing to the carburetor adjustments, are using a fresh (1.5 months or less) fuel mix with the same oil/fuel ratio, are operating at the same elevation, and the air filter is clean, there is a reason your saw is acting up. Most often it is a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. HTH Lou
The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
my chain saw will not start up and it has a new carborater and it was just running fine a few days...
(More)
my chain saw will not start up and it has a new carborater and it was just running fine a few days ago what could be the problem
what are the factory jet settings - idle, low speed and high speed for the Poulan Pro 335? (number...
(More)
what are the factory jet settings - idle, low speed and high speed for the Poulan Pro 335? (number if turns out) It was running fine, but suddenly wouldn't keep running. I cleaned the air filter, replaced the plug, put fresh gas in it. Then it started, ran fine, but idled too fast. So, I adjusted the idle speed. Bif mistake. Now it won't keep running. It starts right up when choked, and runs for just a few seconds and dies. Then starts right up, unchoked, runs for a few seconds, and dies. I want the jet settings so I can have somewhere to start. Help!
How can you tell what the year of manufacture of Husqvarna 136 chainsaw. the owner can not find...
(More)
How can you tell what the year of manufacture of Husqvarna 136 chainsaw. the owner can not find manual and does not know the fuel ratio. One online manual showed 40:1 and the other 50:1. It depended on the year range can you tell me from the serial # thanks Larry McCay
i have stripped the saw for cleaning and the brake part with the pressure washers got me. i dont...
(More)
i have stripped the saw for cleaning and the brake part with the pressure washers got me. i dont know in what sequence it must go in.How do i fit the pressure washers on the motor for the slip clutch/brake Where can i get a assembly drawing of how to put everything back toghether? Thanks Markus
Homelite XL1 13inch. Chain saw.won't start probably due to ignition switch, spark plug is good. Was...
(More)
Homelite XL1 13inch. Chain saw.won't start probably due to ignition switch, spark plug is good. Was working fine
