Trying to fix this machine for a friend.Stihl TS510 Cutter. Good spark, Fires nearly every time you pull the starter but wont pick up and run.Carb and filter are clean. Any ideas?? The plug is new. Have reset carb H & L to settings in manual.
I have a Makita sr 1800 circular saw. How do you set depth of cut? It has the standard lever to do...
(More)
I have a Makita sr 1800 circular saw. How do you set depth of cut? It has the standard lever to do this but shoe plate cannot pivot.
hi , i have bought a hitachi set .drill ,rip saw ,and torch. 18v. the first 2 times i used the torch...
(More)
hi , i have bought a hitachi set .drill ,rip saw ,and torch. 18v. the first 2 times i used the torch the bulb blew both times . the drill has been intermitent and the saw has stopped working .i bought 3 battery and have been great but now i have only 1 tool to use . have there been many faults .the tools are great when they work.
I need an owner's manual or assembly manual for a Pro-Tech 7208 miter saw. (I lost the original...
(More)
I need an owner's manual or assembly manual for a Pro-Tech 7208 miter saw. (I lost the original owner's manual.) Do you know where I can get one?
