Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Whirlpool Drop-In rear burners shut off
I have a rather old Whirlpool Drop-In range/oven? There are four burners, and the front two work, but the rear two don't function properly. They will turn on, and heat up, but after 4-8 minutes, they will turn off completely. Can you help?
  • hyattmom Jan 05, 2008
    Actually, it's an electric range, I probably should have mentioned that. Any other ideas?
  • 619 Answers
The gas line was stuck clean nozzle w/ small neddle and clean burner set the edge of the burner in order complete gas will be burn.
Posted on Jan 05, 2008
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Jan 20, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Oct 17, 2008 | Whirlpool Kitchen Ranges
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
95 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
