Did you connect the blue amp turn on lead to the remote input on the amp?
Some headunits have two blue wires. One is for the antenna and the other is for the amp. If you have sound on the radio but not on cd then the wrong blue wire was used. If you can give me som more detail on the wiring I can help you further. You can test to see if the amp remote turn on lead is providing power to the amp with a meter or a light probe. If you are in fact getting power to the remote terminal and to the main power terminal then check the fuse(s) and make sure the drounding terminal is secured well. If you drilled a screw into the body for the ground then you need to scrape the paint from the body where the ground lug is connected. Also could be a relay inside the amp.
Let me know if any of this helps and what you find and I will be glad to assist you further.
I'm trying to install the Roady XT SA10175 satellite radio to the Alpine CDA-9856 CD- reciever for...
(More)
I'm trying to install the Roady XT SA10175 satellite radio to the Alpine CDA-9856 CD- reciever for best sound quality. Is there a port on the reciever for a direct wire from the satellite radio?
when i plug the wiring harness into my jvc Kd g120 it turns on saying see you, then wont turn on...
(More)
when i plug the wiring harness into my jvc Kd g120 it turns on saying see you, then wont turn on again.
My xdm6820 has no display showing. What do you sugest? Any ideas? It works fine but can not see...
(More)
My xdm6820 has no display showing. What do you sugest? Any ideas? It works fine but can not see clock or radio station. No display at all!!
i recently installed a used sony cdx s2010 stereo in my car,i don,t have the owners manual to...
(More)
i recently installed a used sony cdx s2010 stereo in my car,i don,t have the owners manual to instruct me how to set the current time,other than this little ordeal(this sony rocks)
