HP PSC 1350 All-In-One Thermal Printer
Problem for HP PSC 1350 All-In-One Thermal Printer
HP psc1350 shows 'E' code when new toner cartridge is installed
By judski189 on Nov 04, 2009
The printer showed that the black cartridge needed replacing. I installed a new one (fresh from Argos) but the 'E' code showed. I put it in several times.
I have now tried with a second one and am getting the same result.
I cannot scan either.
These are not HP brand but I am reluctant to spend money on HP n case the printer has failed and I have to buy a new one anyway.
I have mislaid the manual so am not sure what the 'E' code indicates
Comments:
Nov 05, 2009
- Thank you for the prompt reply but the problem is that the printer does not work - whether it has wi-fi capability is another thing entirely
Solution #1
posted on Nov 04, 2009
Not Helpful)
clive_gray20
Rank: Wiz
Rating: 83%, 27 votes
you could use a belking usb network hub http://www.belkin.com/uk/networkusbhub/
This plugs into your router then you plug in your usb devices and hey presto, they can all be accessed by any computer on your network.
So I guess the answer is yes if you're accessing your network using wifi.
Was this helpful?
Yes
No
Popular Solutions for HP PSC 1350 All-In-One Thermal
Questions and Unsolved Problems for HP PSC 1350 All-In-One Thermal
Do you recommend HP PSC 1350 All-In-One Thermal Printer?
Answer
Answer
my printer is not printing its stuck on deleting a paper & wont print or delete it
Answer
hp 1350 all-in-one. all the lights are lit, now it wont do anything .
Answer
after changing ink cartridges we are unable to print on 1350 all in one. we cannot download align... (More)
Answer
Changed PCs, went to Vista OS. CD used with XP will not install because of OS. Need the director to... (More)
Answer
hp psc want print or copy gives error check ink cartridge changed cartridges (both black &... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
