Question about Kenmore Kitchen Ranges
Bake element won't work
Our bake element was touched by tin foil and blew. We replaced it but it still won't work. Everything else works including the broil element. There are no fuses on our range (Kenmore C968-53070-1). Is there something we need to reset or replace other than the element?
Amigaman
  • 248 Answers
SOURCE: broil element will not work
You need to check the oven sensor. It should be about 11k ohms. This is the metal rod in the back top of oven cavity. Access it from the rear. UNPLUG POWER FIRST!!
Posted on Nov 04, 2007
SOURCE: tin foil baked onto bottom of gas range oven
rape it
Posted on Oct 09, 2008
SOURCE: KGST307 Gas Kitchen Range: gas range will not heat up when using Bake setting...
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
  • 842 Answers
SOURCE: bake element burned out on
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Jul 26, 2011
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Posted on Nov 24, 2011
My oven won’t heat up
Could be the bake element or the board If it has a oven control board. If the board is bad it won’t bake or broil so try broil if that works it’s the bake element that you’ll need to replace
May 08, 2018 | Ovens
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Maytag gemini bake element not getting power
First, check the probe. With a multi-meter it should read 1100 Ohms. If reads anything different, replace it. Here is that part to order.
If the probe is good, you will need to replace the control board. Here is that part to order.
Feb 17, 2013 | Maytag MER6772 Gemini Electric Kitchen...
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
My oven won't work on bake but everything else is operational
Most likely have a bad heating element. Check for continuity in the element. Make sure to trip the breaker or unplug the unit before removing the element. 120 volts still run through the element even though it is not turned on. Takes 240 volts to make it glow red.
Apr 03, 2009 | Maytag MER5530 Electric Kitchen Range
Oven doesn't work after replacing the bottom (baking) element
Will the clock control accept the bake and temperature request?
If so,
You will need to remove the rear panel of the range and test the bake element leads for 220 volts when the oven control is set to bake and is turned on.
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How do I remove tin foil baked on brand new oven bottom?
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacement part for your unit, and if they do it will be costly. Your warranty will not cover it.
Jan 09, 2009 | Kitchen Ranges
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Bake element t
I'm just guessing here...
Heating elements are high resistance. If the foil fell on the element near where it inserts into its socket it could have short circuited the element. If there's a fuse in the heating element wiring it could have blown. I could not find an electrical diagram for this stove so I don't know if it has a fuse or not.
Also, depending on the wiring your thermostat or selector switch may have been damaged. Does the broiler still work?
Let us know what you find.
Dec 09, 2007 | Tappan TEF242 Electric Kitchen Range
Kitchen Ranges Logo
110 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
