RCA 36V430T 36" TV Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any way to reset my TV back to the original manufacturer setting?
John Morganti
Level 3:
  • Master 864 Answers
  • Posted on Nov 04, 2009
John Morganti
Master
Level 3:
Answers
864
Questions
Helped
373944
Points
2813
Use the PRESETS button on the remote control. See page 9 of the manual here: http://tv.rca.com/RCATV/Assets/pdfs/36V430T_1616262B_IB_e-05.pdf
I have a sonic TV and can't retune, because of a code lock which I don't have
If you have forgotten the code lock for your Sonic TV and cannot retune it, you may be able to reset it back to factory settings by performing a factory reset. However, please note that this will erase all custom settings and data, and revert the TV to its original state.
To perform a factory reset on your Sonic TV, follow these steps:
  1. Turn off the TV using the power button.
  2. Unplug the TV from the power outlet.
  3. Press and hold the power button on the TV for 15-20 seconds.
  4. While still holding the power button, plug the TV back into the power outlet.
  5. Continue holding the power button for another 15-20 seconds, then release the button.
  6. The TV should now reset to factory settings.
Please note that the steps may vary depending on the specific model of your Sonic TV. If you are unsure or if this method does not work, you may want to consult the instruction manual for your TV or contact the manufacturer for further assistance.
Mar 19, 2023 • Cell Phones
How do I reset my AIm 32tv locked no remot
To reset your AIm 32TV without a remote, you will need to follow these steps:
  1. Locate the "Menu" button on the TV: The button is usually located on the side or at the bottom of the TV.
  2. Press and hold the "Menu" button: Press and hold the button for about 10 seconds or until the TV turns off.
  3. Turn the TV back on: Press the "Menu" button again to turn the TV back on.
  4. Look for the "Factory Reset" option: Once the TV turns on, navigate to the "Settings" or "System" menu and look for the "Factory Reset" option.
  5. Perform the factory reset: Select the "Factory Reset" option and follow the prompts to reset the TV to its original settings.
Note that these steps may vary depending on the specific model of your AIm 32TV. It's also important to check the user manual for the correct steps.
If you are unable to find the factory reset option, or if the TV is locked, it may be best to consult the manufacturer or an authorized TV repair center for further assistance.
Who would be able to help me with my t.v? the color settings are messed up
The best way to reset your hardware is to actually contact the Manufacturer. Ask how to reset the TV to FACTORY Settings. Original settings are generally the basic and best method to view TV from the start.
NEED CODE TO PROGAM TOSHIBA TV
Hi
You can trye this:
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Unlock my sharp 21G-fx10 TV
Unlock all of the channels on the TV by entering the factory-reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
How to reset television to turn back on...
1) reset the c. breaker 2) unplugeed the power cord by 10 minutes. and try again. 3) you can go to the MENU and work by default or to go to the set up from original manufacturer.
God bless you
2answers
How to take the tv back to original factory settings
Unplug,replug the tv back about an hours later.All the tv settings,will return back to the tv original factory settings.
3helpful
How can I get my Olevia tv back to the factory settings?
It's at the bottom of the Miscelaneous Menu (Book & wrench icon):
"Reset Factory Settings:
Initiating Factory Default will reset all OSD settings to original
manufacture settings. The only items, which will remain unaffected are:
Clock
Auto Scan Channels
Edited Channels
Parental Control Password "
If you are trying to take off the parental password:
"Note: If you forget the password, press "9999" to lift the Password lock
and change to a new preferred password. "
"" = Quotes straight out of the manual.
2helpful
Initial setup on Bravia 26" won't come up
Try resetting the TV to the original factory settings. After resetting the TV to the original factory settings, you can get the initial setup screen to select Antenna. Make sure that the cable from the Antenna is connected to the TV.
Follow the steps given below to reset the TV to the original factory settings:
(i) Turn ON the TV.
(ii) While holding down the Up arrow button on the Remote control supplied with the TV, press the Power button on the TV set. The TV will turn itself off then back ON again.
(iii)Next, release the Up arrow.
2answers
Full Picture Display
It's definitely not convergence. Sounds like more of a problem in the horizontal section.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
