Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech 500G HD
I have a 500 GB, I plug it in, connect the USB, turn it on, the blue lights flash for a second and the drive whirs a bit and then I get a blinking red light it blinks 9 times and then nothing.
  • Anonymous Dec 01, 2008
    I have the same problem, but this happened after a fall :(
  • Anonymous Jan 05, 2009
    Any resolutions to this yet?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
That means system wont support the drive or you are having problem with the detection or driver.
some system wont detect the drive with large size without drivers.
Posted on Jan 06, 2008
My fabrik simpltech 500g hd doesnt work on anything but my macbook, is it locked?
If it's formated under MAC OS, windows will never see partitions on your hdd.
Dec 25, 2011 | SimpleTech 500GB SimpleDrive Pro External...
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have a 500gb simpletech hard drive that I have lost the power adaptor. I need to know what size to buy.
The simplest way is to ask SimpleTech
Your Part number: PRO500Q
Customer Support Phone Number Tel: (949) 477-7700
(6:30AM-5:30PM PST Mon-Fri)
or send them a tech support request at...
Aug 11, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
500g simpletech extrenal harddrive will not turn on
Sounds like a drive failure. If it under warranty then its time to trade it in.
Jul 29, 2009 | Western Digital 500GB My Book Pro-External...
Can't detect my drive
It could need a power adapter if it cannot draw enough from your usb port. I would try another port on the back of your PC.
Aug 02, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Simpletech 500 GB drive won't work (repost because not solved)
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Dec 09, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Open your Simpletech by removing two screws from the back --> you need to remove the label in the back, and pull the I/O card up towards you. The I/O card comes off easily.You need to buy a BYTECC USB 2.0 to IDE/SATA ADAPTER Kit ( you can buy this adapter on line, It ranges from $16 to over $30). Now connect the USB port from the adapter kit to your USB port, and plug in the Adapter kit to a 115 volt power outlet. If the hard drive is not shot, that is, you feel it spinning, you should be able to see the drive, and copy the data from your SimplechTecj drive to your PC.
Aram Dodakain
e-mail to
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
399 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
