Question about Lexmark X1240 All-In-One InkJet Printer
Paper jam I am having the same problem as the first poster. I have looked for an obstruction and there is none. I have tried different paper - didn't help. It has not been used in a couple of weeks during the holiday????I am a teacher and I need my printer! HELP ME! T
  • isjord Jun 09, 2008
    The paper feeder will not work. The paper will not feed down in the printer. I pulled a piece of paper out of the printer it was jammed and then it would not feed anymore. What could be the problem?
    Genius:
  • 2,035 Answers
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Posted on May 14, 2008
HP 970 cse printer Orange light flashing, but no papter jam. Green power light is lit. cannot print ? :(
There may be a small piece of torn paper in the path obstructing a sensor. Have a good look to see if you can find it.
Jul 26, 2016 | HP DeskJet 970cse InkJet Printer
When i try to print a page to paper just gets all chewed up on the right hand side and stops printing
hi, for this issue to resolve check for any obstruction in right side of the paper path and clean drive roller with moist lint free cloth.
venkateshwar, hp technologist, contact 8686427911.
Sep 21, 2011 | HP DeskJet F380 All-In-One Printer
Printer is jamming paper and there is nothing there to be causing the paper to jam
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any debris or foreign objects. If you're capable and willing, you may carefully lift the printer upside down so that any debris in the feeder will just freely roll out. If none debris found, lift the printer cover and remove the cartridges. While the cover is open check for any obstructions in the paper path. If none, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper. Try to print again. If paper jam continues, please don't hesitate to contact Lexmark technical support for additional assistance.
Apr 21, 2011 | Lexmark X2500 All-In-One Printer
Copies are jamming or ejecting looking like an accordion. What's the fix?
This is usually caused by something caught in the paper path. Open the printer, remove the toner and look for any obstructions in the paper path.
It also may be caused by the type of paper you are using. Try using paper from a different ****.
Hope this helps
Please rate this solution, thanks!
Mar 07, 2011 | Brother MFC-7820N Printer
Hp 309n false paper jam
just fixed mine! So easy, just cut a piece of poster sheet down to paper size and pushed it through the printer. Works fine now. (I had the false paper jam error message, The printer doesn`t know the difference between a stiff roller and a paper jam!)
Dec 06, 2010 | Office Equipment & Supplies
Brother MFC 7420 - paper jams in fuser unit -
Its probably the pickup roller and/or separator pads. Another possibility is a tear in the fuser heat cover. IF you can manually rotate the fuser(when its cool) you can see if the fuser roller has any problems. Last thing is make sure its looking at the right paper size. Maybe reset all software settings and start over? If its looking for one size and seeing another, it may cry jam.
Feb 02, 2018 | Brother Office Equipment & Supplies
PAPER JAM EVERY THIRD COPY OR SO, I HAVE TO OPEN REAR COVER TO REMOVE PAPER JAM. LOOKS LIKE ROLLERS ARE CUMBLING UP THE PAPER
hi there !
regarding issue/s with paper jam, you may do the following procedure
-Locate and slowly pull out the stuck paper from the Dell™ inkjet printer.
-Locate and Remove Any Obstructions Inside the Printer and Input Tray
-Clear Any Stuck Paper From the Auto Document Feeder (ADF)
-Adjust the Printer Paper Guides
-Extend the front paper support on the printer.
-Try a Different Piece of Paper in the Printer
-Reseat the Dell Printer Power Adapter
-Try a Different Type of Print Media
If all else fails you need to Replace the printer.
cheers !
Oct 26, 2009 | Dell Office Equipment & Supplies
HP PSC 1500 series print cartidge cradel cannot move?
Does is look/sound like the cradle is attempting to move? Make a loud popping sound? There is small belt that is used to guide cradle across the platen. Take a closer look to see if anything is obstructing that belt. It's rubber and looks like it has gear teeth on it and fits around white gear wheels on side of cradle.
If it doesnt' move at all, a hard reset might clear it. You'll have contact HP support for that as each printer model is different. Some you just hold the power button in for a certain number of seconds.
A soft reset can be tried by unplugging power cord from printer and waiting 15 seconds then reattach power.
Oct 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Canon imageRUNNER C3200 Copier troubleshooting paper jams. The copier will jam, i will removed the jam paper for i can have a fresh start. i will try to copy again and the paper will jam again. can any one...
It could be a few different reasons the printer is jamming.
The pickup rollers could be worn; There could be an obstruction in the paper path the fuser could be bad
It all depends really on where the unit is jamming (Ie where you have to take the paper out from)
If the copier starts to work, and then gets an error but no paper travels into the unit the pickup rollers are the likely culprit.
If the paper stops somewhere in the middle of the copier, then an obstruction within the paper path must exist or some other internal failure.
IF the paper jams at or in the fuser then yes the fuser is the problem.
Hopefully this helps and feel free to add another comment with more info or questions :)
Sep 03, 2009 | Office Equipment & Supplies
Paper always on right when loading to be printed
Canon Printers are notorious for paper jams. Don't throw it out the window just yet, there are several solutions. Visibly check that there is nothing obstructing your printer (use a flashlight). A kitty may have hacked up a hairball (just kidding). Try a can of compressed air to blow out any foreign objects as well as turning your machine gently upside down to be absolutely positive nothing is obstructing the roller assembly. Next, open your Word Pad and type anything (like how much you are enjoying your Canon Printer Jamming and how you will recommend Canon Printers to all your friends), Use an A4 paper size 'POSTER PAPER' (the same size that you normally use (8 and one half inch by 11 inches) as this is thicker than what you would use. From your Word Pad, click PRINT, you will need to run the paper through several times and this will clean out any built up residue. If you do not have 'POSTER PAPER' a 'MAGAZINE COVER' will suffice (just be certain that it is the same size). After you have run your 'POSTER PAPER' through, load your regular printing paper normally and this should resolve your 'FANTASTIC CANON PRINTER'.
Oct 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark X1240 All-In-One InkJet Printer Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
