Washing machine problem
Hi i have an indersit w133s washing machine, when you set a program it can take hours for the selected program to start. sometimes it can take all night before it starts to fill with water and start the program. can anyone help??
  • Anonymous Mar 14, 2014
    indersit washing machines wont tun on after belt broke
  • 183 Answers
Possible sticking door lock or a faulty PCB located in the back of machine, however watch the red light and count the flash pulses, if there is a compnent fault the self diagnostics should emit a fault code, the light will pulse and then pause, you need to count the pulses between the gaps.
Posted on Jan 04, 2008
Accidently pushed delay start, now annot wash
Hi sallysue5928 - How long was the delay start set to? Typically the delay time selected will be displayed as 30, 60, or 90 minutes or 2 through 14 hours. However, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful then unfortunately you will have to wait till the time of the delay start cycle that was selected.
Feb 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Wen a program is selected it just goes on for hours but never washes and clothes stay wet
Possible that the program controller unit is a suspect. If there is no output from the program controller then the output must be checked.
On start it must open the inlet valve to fill and after the level is reached to start the wash cycle. If not the controller is a suspect.
Jan 19, 2013 | Washing Machines
Second wash/rinse cycle for heavy loads must be engaged manually. is there a way to set it to start automatically?
Possible fault in the program controller unit. If the menu can be set up manually then select the wash/rinse or drying seperately and press start.
In most machines this is possible to override the program just in case the auto mode does not work orr the said program has errors.
Apr 19, 2011 | Washing Machines
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
Replaced door handle on indersit w93 now machine wont work
is your door switch wires back on that you may have taken off or is it making contact with door switch
Jun 10, 2009 | Whirlpool LHW0050PQ Front Load Washer
Bosch Washing MAchine - E2 error message
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Jan 31, 2009 | Bosch WFMC 3200 Front Load Washer
Indesit W133S front loader
hi there the filter is at the bottom of the machine behind the kickplate but if you are getting a bad smell it is more likely your machine needs a service wash ie. run some old towles through on a 90 degree cycle with some soda crystals.
hope this is of some help
Dec 07, 2007 | Washing Machines
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
