Question about Mercury P4VM800M7 Motherboard
My PC Wont Boot Up???
I am using P4VM800M (Chipset P4M800) Murcury Kobian Motherboard With 2.13 Intel Celeron D Processor (Socket 478 mPGA), My System Wont Boot, It power on but dont disply anything. then i press reset button several times then it Boots & display Mercury Logo then. Please Fix My Problem :( & also system dont install drivers for
1. USB-Serial Controller C
2. Standard Floppy Disk Controller
3. Communication Port (COMM1)
4. ECP Printer Port (LPT1))
please help me fix my PC, It will be so Nice of you.
Best regard,
Waqar Khurshid.
Email: suisboy@yahoo.com
  • 1 more comment
  • Waqar Khurshid
    Waqar Khurshid Jan 06, 2008
    its P4VM800M Murcury MotherBoard With 2.13 Celeron D Processor, Problem is not That kind Off Its is that my PC wont start. it wont beep or POST(Power On Self Test) until i restart it several times.
  • SMOKEHOUSE67 Apr 11, 2008
    I HAVE A P4M800PRO-M478 WITH DDR2 1GB MEMOREY MY SYSTEM WILL NOT BOOT UP OR THE MONITER WORK ITS NOT OVER A YEAR OLD ,HOW CAN I GET IT TOO BOOT UP AND RUN? THE FANS AND THE DVD DRIVE ALL TURN ON AND YOU HEAR THEM RUNNING ALSO.
  • Anonymous Apr 15, 2008
    vga
  • 3 Answers
Dear Waqar Khurshid,
What model is your PC and you should do right now is to insert a Bootable CD and troubleshoot the sysem
Posted on Jan 05, 2008
2 Suggested Answers
spare_head_2
  • 47 Answers
SOURCE: Sytem Wont Start
Hi suisboy,
This sounds similar to a problem I had with a clients PC. The best way to debug this is to swap out one component at a time and see it it fixes your problem. However, if you can't do this then I'd suggest you try the following in this order.
  1. Remove all cards from the PCI bus leaving only the graphics card in place.
  2. Unplug all drive cables from the motherboard and power from the drives.
  3. Try to boot the motherboard. If successful try this, several time and if you don't have any problems you are okay to proceed.
  4. Enter the BIOS and load load the Default settings.
  5. Enter the BIOS and make it run the system check to fully test the memory.
  6. One by one re-attach your drives, if the system is stable continue to add you PCI cards until you hit the problem again. This will be the incompatible or faulty card.
This procedure should allow you to find the component that's causing your bus timing fault.
I hope this will help you diagnose your hardware.
Regards,
Spare head 2
Posted on Jan 06, 2008
Cpu suport
Going with problem heading stating ->
IBM 73P0595 motherboard > CPU Support > and previous problem statement ->
"I have updated my processor from INTEL Pentium d 820,2800mzh 1500mzh to INTEL Pentium d 945,3400mzh....."
Let's take a look at the IBM 73P0595 motherboard specifications, first;
http://www.epinions.com/specs/IBM_System_Boad_W_O_POV_10_100_73P0595_Motherboard?sb=1
http://www.ebay.com/itm/Lenovo-73P0595-ThinkCentre-M50-A50-Motherboard-SOCKET-478-2-4GHz-Intel-CPU-/200870757822?pt=Motherboards&hash=item2ec4d485be
A) Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
B) Intel 865G motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
The Intel 865G motherboard chipset DOES NOT support dual core processors.
Does NOT support an Intel Pentium D; 820 OR 945
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.2865_nm.29
Those two processors also use the LGA 775 processor socket.
(Socket T,
http://en.wikipedia.org/wiki/Socket_T )
What did you base your CPU support on?
Was it the fact that the Intel 865G motherboard chipset, will support Intel Celeron D?
http://en.wikipedia.org/wiki/Celeron_D#Celeron_D
The Intel Celeron D is NOT a dual core processor,
"The Intel Celeron D processor works with the Intel 845 and 865 chipset families.
The D suffix actually has no official designation, and does not indicate that these models are dual-core.
It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M......"
Not the IBM 73P0595 motherboard we're talking about?
OK.
Let's just base it on the statement that you tried to upgrade, from an Intel Pentium D820 to an Intel Pentium D945,
http://www.fixya.com/support/t13549945-update_intel_pentium_d_945_procesor
What motherboard are you using?
Motherboard in a HP Compaq DC7600 Desktop PC?
http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Scroll down to the bold subheading -> Processor and Speed
Intel Pentium D820 at 2800MegaHertz (2.8GigaHertz),
with 800MegaHertz Front Side Bus, is supported.
(800MHz FSB)
Probably came with your computer, huh?
Intel Pentium D945 at 3400MHz (3.4GHz), with 800MHz FSB is supported also.
This can be seen by the specifications of the motherboard chipset, also. The Intel 945G motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
Scroll down to 945G in the left column. (Last one listed in chart)
Apparently you just needed the 786D family Processor Microcode Update, or did that not work out?
Awaiting reply,
Regards,
joecoolvette
(How did I come up with the HP Compaq DC7600, anyway?
Did you add it in a Comment, and it has been removed, or what?
!O_O! )
Jan 02, 2013 | IBM (73P0595) Motherboard
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
Support dualcore?
That is a socket 478 motherboard. I doubt that one even gets dual core processors in the 478 chipset. Also according to the ECS website, this is a Pentium 4/Celeron board. More info can be found here.
Nov 16, 2010 | EliteGroup ECS P4M800-M Socket...
Evo d510 small form factor with 1.79ghz processor what other size of processor can i put in
The Compaq Evo D510's motherboard has a Socket 478 processor socket, and uses an Intel 845G motherboard chipset.
This is information on the Socket 478 processor socket,
As you can see the processor socket has the holes, while the processor has the pins.
478 socket holes.
Only Intel processors that fit into a Socket 478 processor socket, can be used.
Intel Celeron or Pentium 4.
Motherboard Chipset:
The motherboard chipset consists of the Northbridge chip, and the Southbridge chip.
Chip and Chipset are slang terms for I.C.
Integrated Circuit.
The Northbridge chip handles the high-speed processes, while the Southbridge handles the low speed processes of a computer.
The Northbridge handles the Processor, Ram Memory, and any high speed graphics.
(AGP and PCI Express being high-speed graphics.
Any graphics adapter card inserted into a PCI slot, or Integrated Graphics {On-Board), is a slow speed process. Handled by the Southbridge chip)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[CPU stands for Central Processing Unit, or for short - Processor)
This is information about the Intel 845G chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Scroll down on the left until you come to -
845G
Read across.
The Nothrbridge chip is the Intel 82845G.
The Southbridge chip is the Intel ICH4.
As you can read looking across, and at the top of the chart, the 845G will support processors with;
1) Celeron, Celeron D, and Pentium 4 processors.
2) Up to a 533MHz FSB. (533MegaHertz Front Side Bus)
(Pentium 4 processors are better than Celeron.
The Celeron was designed as a budget processor.
'Celey's' generally have half of the L2 cache, that a comparable Pentium 4 has)
I felt listing this information in this manner, would help you can make an informed decision, as to what processors are compatible with the Evo D510 motherboard, instead of just stating, "Get this processor".
I will include a link of a website I found some time ago, that sells Pentium 4's with these parameters, at a very reasonable cost.
May 07, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
I have 2.6 celeron processor with intel 865 motherboard i am up grade tell us who is processor best
on mb with intel 865 the bigest CPU is pentium 4 @ 3GHz. socket 478
however your MB might require to update microcode for the new CPU.
one more thing: this chipset Intel 865 is obsolete, and intel does not manufacture this cpu type anymore.
Feb 22, 2009 | HP Celeron A , 2.6 GHz (DL458AV) Processor...
How to place an Celeron processor on ASUS P2L97 motherboard
You cannot use an Intel Celeron processor on this motherboard. the motherboard you have is a slot 1 pentium 2 board whilst the celeron uses socket 478 pentium 4 processor platforms
Jan 03, 2009 | ASUS Intel 440LX Chipset P2L97-DS...
MSI MS-6754 mother board won't boot and beeps when I swap processors
your motherboard has the chipset of 845GL series
so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
Sep 06, 2008 | Computers & Internet
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Sytem Wont Start
Hi suisboy,
Regards,
Spare head 2
Jan 06, 2008 | Mercury P4VM800M7 Motherboard
Mercury P4VM800M7 Motherboard Logo
383 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
