Question about Canon PC-980 Color Copier
Canon pc980 as soon as unit is powered up, "E0" error code lights and unit shuts off. I love this copier and hate to dispose of it. any ideas and is it worth fixing? thanks
    President:
  • 4,402 Answers
Reset the error code in the program,if the error code is still there check fuser unit then the optic sensor
Posted on Jan 04, 2008
Turn power off and then on it
Canon Printer error code E0
To reset that error remove the two screw in both side of control panel then after that remove the control panel then you will see a board in that board just look for two terminal there is service indicate in that terminal just make it shorted that 2 terminal then turn on the power switch
Oct 03, 2012 | Canon Office Equipment & Supplies
We have a Canon PC980 black and white copier. When the "on" button is pushed, the error message "EO" appears. The copier will not operate at all. HELP!!!
E0 means a fuser problem, it does not heat up properly. It could be the heat element within the fuser or the overtemp fuse may have blown.
Anyway, you should really have an technician look at it for you.
Jul 05, 2011 | Canon PC-980 Color Copier
How can clear error e000 from my canon pc980 copier
Error 000-means an Error caused trough an ruined fixing unit. You have to Change the unit, the Mainboard or bring to a Repair Center, I am afraid...
Dec 22, 2010 | Canon PC-860 Black and White Copier
I have an old Canon PC941. It has code E0 (which
yes its the fixing film you must replace it and you must do a reset of the error .
Apr 09, 2010 | Office Equipment & Supplies
Get error code E0 immediately on power up and then shuts off
Check the main thermistor and the fuser unit components.
Oct 07, 2009 | Canon Office Equipment & Supplies
I have an E0 code
Check the main thermistor,the thermal switch,the heater lamp.This components it is in open circuit.Reset the error code in service mode.
Sep 27, 2009 | Canon NP 6551 Black and White Copier
Canon copier PC785 displays E0 and turns off
fuser unit is located near the printing
output
Sep 02, 2009 | Canon Office Equipment & Supplies
Canon PC785 fails and turns off immediately after turning on. Displays code ''EO'' just befor shutting off
E0 error means Fixing Unit failure. It could be a dirty Thermistor. It could be an open Thermal Fuse. It could be an open Heater Lamp. Anyways, once the culprit has been isolated and corrected, the copier will need to be reset via "jumpering" certain points on DC Controller.
Jun 22, 2009 | Canon Office Equipment & Supplies
Canon 745
hello sir
machine error code zero is the first digit when its blinking,there is another # to show? must be 2 digit,but base on your explanation you must change the exposure lamp or scanning lamp
Dec 12, 2008 | Canon PC-940 Black and White Copier
Error "E0" on a Canon NP 7130
E000 on a 7130 is a lockout error it needs to be reset. you need to remove the control panel remove the 2 screws that attach it to the body on the left and right sides open the **** shell and pull toward you. Flip up on the top of the unit with the circuit board facing you look for two metal jumpers labeled jp103 and jp104 short across the 2 with a small screw driver to enter service mode( can be verified by an "F" in the display) power down the copier reinstall the control panel and reboot. If the fixing assembly is good the error will be cleared
Oct 29, 2007 | Canon NP 7130 Black and White Copier
Canon PC-980 Color Copier Logo
260 people viewed this question
old marine
old marine
