Presto 1500 watt quartz space heater model #0787701
I'm missing one of the two heating elements. Any idea where i could find one.
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: quartz heater parts
check out this site for heater parts.
http://www.infraredheaters.com/quartz1.htm
Posted on Nov 29, 2007
burzerko
  • 254 Answers
SOURCE: Need switch fort Presto Quartz Heater
Hello
Any hardware store should have a replacement switch for you. Let me break the numbers down to help you out.
INF = Infinite switch
120 = 120 volts
887B = model number of the switch
34-191 = date code
15 amp = ampacity rating of the switch
120 vac = Again this is a 120 volt switch A/C
If you need anymore assistence please comment back.
Posted on Jun 04, 2008
SOURCE: Presto Quartz Heater element 1500 watts
We have a Presto quartz heater and have gotten replacement tubes from: National Presto Industries, Inc., P. O. Box 1172, Eau Claire, WI 54702-1172
In 2004 the cost was 26.00 for two (S&H included). We bought the heater in 1984 and it is still running great - we love it!
Posted on Sep 20, 2008
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
Info on presto quartz heater model 0 789201
Contact the manufacturer.
Nov 15, 2014 | Dryers
IS IT POSSIBLE TO REPAIR A QUARTZ HEATING ELEMENT
yes. but it may not be cost effective.
just buy the elements from ebay
Oct 16, 2013 | Toastmaster Heating & Cooling
My fostoria spacer stop producing heat model 1520 3A. Smell a burn odor fan still works. Sounds different too. can you help? Dennis
Your electric space heater works by using a quartz infrared element, something that can eventually burn out due to use/defects. To fix your space heater, you will have to get another element specific to your model fostoria. While I did a quick search online, I could not find any matches to a replacement, but you can still call the company for one. Before calling, though, check to see if your heater is still under warranty, probably 1 to 2 years. The number for fostoria is 1-800-495-4525. Best of luck.
Mar 03, 2011 | Fostoria FES - 1520 - 3A Heat Wave Utility...
Need replacement quartz tube <17" for my Presto
If Presto longer manufacturers or stocks parts for your heater, there may be a good reason for it. Other than they now have a better heater. My best advice is to scarp the heater and purchase a new one, Your model may have had a safety issue.
Jan 27, 2011 | Heating & Cooling
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Hello
120 = 120 volts
34-191 = date code
May 06, 2008 | Heating & Cooling
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Hi, you can find it on amazon for sure, here take a look: Amazon com Quartz Heater element 1500w. I hope this was helpful. have a nice day
Dec 07, 2007 | Heating & Cooling
Quartz heater parts
I have an older presto quartz heater thats needs a thermostat the info on the switch is as follows
INF-120887B 34-191 15AMP 120VAC can anyone help me out? thanks fred
Nov 28, 2007 | Heating & Cooling
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
