Question about Canon PIXMA MP830 All-In-One InkJet Printer
Ink Tank Hi, I accidentally put a BK 8 cartridge into the PGBK tank and now I can't get it out. I'm quite concerned. Any ideas? Thank you!
  • 52 Answers
Hi i am a certified Canon tech for this machine. the only thing that you can do is yank it out with force the worst that is going to happen is the ink chip connector prongs could break but they might already be broken or bent. in this case you will need to find a Canon repair center by calling 1-800-OK-Canon or by looking on their website Canon repair centers are world wide and privately owned. if the unit is less then 1 year old just find a repair center and have it fixed otherwise try forcing the cartride out and hope for the best.
Posted on Jan 05, 2008
Can I replace pgbk 5 with bk 8 in Canon MX700?
No unfortunately. The cartridge shape is significantly different (apart from using diffeent ink) and not of the relevant bits underneath will mate up.
Mar 05, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Canon W8400 E02804
Check x Tank (the ink color is indicated by x)
This is displayed when an incorrect ink tank is installed.
The final digit indicates the ink color.
So you have problem with Bk ink tank...
This is displayed when installation of an incorrect ink tank is detected.
This is displayed when a checksum error occurs in the ink tank EEPROM.
Ink tank, ink tank unit, engine controller, system controller
1. Replace the ink tank.
2. Replace the ink tank unit.
3. Cable connection check
Replace the cable between the ink tank unit and engine controller if the connection is not functioning normally.
4. Replace the engine controller.
5. Replace the system control
So as you can see there is a lot of possibillities, ... call service
Aug 08, 2011 | Canon imagePROGRAF W6400 InkJet Printer
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have problem with print-head for PGBK-5. On the test-print it does not appear as the pattern suppose to be (from the top) PGBK, C, C, M, M, Y, and BK. The pattern always appear C,C,M,M,Y and BK. I used...
if the clogging is worst then the deep head cleaning wont help.the head will need to be cleaned up manually and the waste ink pad in the printer should be cleaned too. this is covered normally in printer servicing.give special instructions to clean the head properly while you hand over the printer for servicing to any local tech. head cleaning and servicing will solve the issue
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have error U071. I have been refilling the
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Feb 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Not recognising ink tank
This is problem with the Bad chip on the ink tank ,Check with new fresh one if it works ok Ask Cannon to replace the damaged ink tank.We had faced many OEM chip with fault
thank you
Feb 17, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Printer says more than one ink tank is installed
I have the exact same problem. It usually takes me quite a few times of taking the tank out and putting it back in to get the machine to comply. Any solutions?
Dec 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
