My Son's Godmother gave me this Sewing Machine, its a Kenmore, but I have no idea what model, or were to look for the model #. (If you want to tell me were to look I am more then willing!) I have used this one and off for different things never having a problem, but I always seemed to use a straight stitch. I am trying to "up my ante", if you will, and was making something with elastic in it using a Zig-Zag. I fig.ed that before I tied to jump in with both feet I would try it out on scrap. It worked fine, but was too wide. I turned the with from 3 to 2 and it was fine. Then I put my project in the machine lining everything up and went to put the first couple stitches in very very slowly with my hand turning the wheel (as I always do) and hit my pin! I push the reverse button and and moved back took my pin out and went to go on... then it got all tight and would not move at all! I lifted the foot and took it all out trying it on my scrap again and after 3 stitches it did it AGAIN. What seems to be happening is that the upper thread is dubbing up (?)/ not releasing to make a stitch when it is going around the bobbin, not the first time but the 2nd, 3rd, ext. Till it gets to the point were it pushes the bobbin case up andwont go around snapping everything and trying to eat my scrap. I tried rethreading the machine and bobbin, tried putting it back to straight stitch, putting the with back, loosing the tension, and just waiting thinking that that might help (at lest my mind). I am plum out of ideas... help :(
TIA!
Comment posted on Jan 04, 2008
I tried just that before and no go, still dubbing up... how do I find out about the timing?
I have a Euro-Pro 7500 (no X) The upper thread is catching and looping in the bobbin case. I have changed the needle, changed the spool of thread, re threaded, checked the tension on the bobbin, checked the upper tension. Nothing seems to help. How do you adjust the timing. My husband is pretty mechanical. If he had a diagram and instructions he could probably fix it. Can you hep me. Thanks a bunch!!
First change the needle for a new one, try a sample sew on some cotton type fabric straight and then zig zag and see what happens, just check the tensions, if it is not picking up the stitches then you have knocked the machine out of time but I think at the moment hopefully it will just be tension problem
Rating Locked! (?) Angil has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sewing Machine, Upper Thread Jamming in Bobbin:
Solution #2
posted on May 15, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I am having this problem also, and it is jerking up the whole bobbin case. I went to Joann's - the lady there said I have worn out the bobbin case and need to replace it.
Was this solution helpful? Show your Appreciation by rating it:
