Back to:
Tags:
Whirlpool AWM8123 Front Load Washer
Wont do anything (by 2 users)
posted by tadghspud on Jan 04, 2008
programme starts after about 10 seconds the door open light comes on and programme stops
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ashmir, posted on Jun 18, 2008
Hi, I have the smae problem.. the machine wn't work and the door open light will go on. but my model is awm 8121. how did u get it fixed?? was there problem with the door latch or a problem with the control panel???
Best Solution
posted on Jan 04, 2008
Thanks for Trying (70)
naynay69a
Rank:Wiz Wiz
Rating: 84%, 51 votes
Maybe door latch adjustment. hold door in at latch and see if it will work
Rating Locked! (?) tadghspud has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on wont do anything:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
Have an LG WD-8074FHB. Machine stops during rinse cycle...
Washing Machines
I recently acquired a used Kenmore Series 80 washing...
Washing Machines
Whirlpool Front loading washer will not work after 9pm...
Washing Machines
My Maytag Neptune washer #MAH550Bww Serial #88922156AJ has...
Regardless of the cycle that you choose, the cycle will...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
