Zanussi washing mashine zwf 1220 w water overflou
Hi guys,
my washing mashine when starts the rinse cicle,has a much stronger water pression than usual causing water coming out fron the soap dispenser drawer,it has been happening with any program I have used.
I have changed the inlet water valve with a new one,but the problem has not been solved,
Any more suggestions?
I also cheked for any blockage everything looks fine.
Thank you
  • 1,294 Answers
Why not just reduce the pressure at the inlet wall faucet. But dont reduce it too much or your clothes wont rinse well.............
Posted on Jan 04, 2008
How do I set spin only for Zanussi Lindo100 ZWF 71263W/71463W washing machine?
With this option you can change the default spin speed.
The indicator of the set speed comes on. Additional spin options:
No Spin
• Set this option to deactivate all spin phases.
Only the drain phase is available.
• The related indicator comes on.
• Set this option for very delicate fabrics.
• The rinses phase uses more water for some
washing programmes.
Rinse Hold
• Set this option to prevent the laundry creases.
• There is a water in the drum when the programme is completed.
• The drum turns regularly to prevent the laundry creases.
• The door stays locked. You must drain the
water to unlock the door.
untitled-pqbhbvgkecedzsp304arfp23-2-0.jpg Dado
Jan 18, 2018 | Zanussi Washing Machines
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
Rinsing cicle is not stoping.Mashine not responding to any baton.How to stop Rinsing cicle and go to normal mode? Thanks Radan
If its is only the rinsing cycle at start up you can go into the menu and turn the rinsing cycle off.
If its the rinsing cycle for the descale, it has to run out of water to finish. Then reprime the machine and it will start to heat again.
Oct 28, 2010 | Gaggia Titanium Espresso Machine
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Its your filter that needs to be emptied; open up the front, locate filter, clean out. Refer to users' manual.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Water pouring from detergent tray
clean the dispenser and draw. now take the lid off the mashine 2 8mm nuts and remove the hose that goes to the drum and check it is clear
Feb 13, 2008 | Zanussi FJS1225W Front Load Washer
Plug off the wall. Open up behind, you will find a thin tube, maybe tranparent or black coming down from the control panel to the exit area (pump area) of your machine. Carefully disconnet this from above and blow into it, it should be free, if not clear it, if kinked or broken replace.
If this does not work, its your solenoid valve at the entrance point of your machine, top right, where the water is received. Just change this. If all works fine rate me please.
Dec 27, 2007 | Washing Machines
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
