Question about Epson Stylus Photo R1800 InkJet Printer
Color is way off from photo I've taken
What gets printed has blue overtones and doesn't look anything like the photo I took and what I see on my screen.  Any ideas?
  • 1 more comment
  • FlashGuy Jan 09, 2008
    Thanks, I'll try that.
  • Sandra Hooker
    Sandra Hooker Feb 19, 2008
    when printing black and white the epsom r1800 prints the black blue
  • Anonymous Mar 10, 2008
    I have the samse problem..colors all have a purple/blue cast, even green leaves..what can I do to correct the color? [email protected]
What I have looked at online could be the idea of maybe your printer nozzle in cloggged for that colour and is over compensating with another colour. Do a colour test and see if this is true. Then try to adjust the other colours to match what you would like printed.
Schtumpy
Posted on Jan 09, 2008
6ya staff
SOURCE:
Photo prints come out with green overtones
do an alignment on the scanner
check for green color level or levels of the composite color cartridge
Sep 04, 2017 | Office Equipment & Supplies
300 dpi nikon coolpix s51
DPI (dots per inch) is an output parameter and has absolutely no meaning to the camera. It has meaning only when you output the photo to a printer or screen.
Let's say you took a photo that's 3000 pixels on the long side. If you then make a 4x6 print, you're putting 3000 pixels into six inches so you're printing at 500 dpi. If you make an 8x10 print, you're putting 3000 pixels into ten inches so you're printing at 300 dpi. Either way, you're printing the exact same picture, only at different dpi settings.
The camera has to put something into the dpi field, so it defaults to 72 which is often used for computer screens. Just about any program you use to print your photos can change this number without affecting anything else.
Apr 07, 2014 | Nikon COOLPIX S51 Digital Camera
Hi - I have a 3-4 year old Canon Pixma IP4500. The initial problem was blurring in places on black text. Nozzle check showed that bottom half of PGBK grid was missing horizontal lines. Took out the print...
one idea is that you rouined printhead with tap water and second idea is to buy new print head or printer.
Note: If you want to replace ink head, be sure to replace purge unit and ink absorber also.
Sep 02, 2011 | Office Equipment & Supplies
33 mm camera photos develop with pinkish green overtone
Your film may have gotten hot or has passed the expiration date. If the tint is splotchy, there could be a light leak, either in the camera or the film cassette after you take it out of the camera. If all your photos were taken indoors under incandescent light, they will also be tinted reddish.
Apr 23, 2009 | Photography
Draining the ink!
Printing photos with Epson drains the cartridges alot faster than printing documents. The dpi settings for photos are much higher to get the photo quality. Blue is a base color that helps to mix to create some of the colors in the photos so this is normal with the Epson brand. Hope this helps.
Dec 24, 2008 | Office Equipment & Supplies
Nokia 7390
i cant think of any reason may be some "bug" in the set...........
venthough   oyu should consukt the nokia personnels ...
Sep 06, 2008 | Nokia 7390 Cellular Phone
Photo ink cartridge stuck
I had the same issue. Don't try to force the cartridge out though. After being stuck to the paper, tearing the remainder of the film won't get all of it out of the cartridge. You'll need to print a 'dummy' page to get the last bit to be pulled out and afterwards the printer will automatically release the cartridge allowing it to be pulled out normally.
Apr 21, 2008 | Canon SELPHY CP720 Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
