Question about ViewSonic VP171s 17" LCD Monitor
Strange colours on VP171s monitor, plus flickering
We have replaced two fuses in our monitor in the last two months.
Today, when we turned on the PC, our screen saver (which was a largely grey picture), is now displaying in lurid pinks, purples and blues, and the screen is flickering. On Windows programmes, our screen bars (title, scroll, etc)have become bright lime green (and the title bar has vertical lines of other colours, some flickering running across it), and when we go on the web, some images and text are unreadable as the backgrounds colours are flickering and too dark, and other images are flickering.
Is it dead?
4 Suggested Answers
joebert
  • 29 Answers
SOURCE: Screen has 1 solid bright vertical line
a mylar capacitor 0.22mf 100v may be shorted besides the flyback transfomer.
Posted on Apr 27, 2007
  • 84 Answers
SOURCE: A line of Dead Pixels.
You are right it is a stuck or dead pixel, usually if it is a colred line but not grey it is a stuck pixel at the beginning of the line you can try a utility designed to flash bright colors repetedly over time to see if this will "unstick" it. Also you could have a dry joint on your TCP which would require opening it up to diagnose.
Posted on Feb 11, 2008
  • 253 Answers
SOURCE: green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
My monitor has been flickering from switch on for about a month. After re-starting 3-4 times it would clear. Then it took up to 8 times then it is just sometimes blank when I switch on. When it is plugged...
its power to the pixels causing the flickering the eletronics controlling which to use may be on its last legs,sorry but it sounds terminal for its use
Jun 22, 2010 | Samsung 226BW Monitor
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Viewsonic vp171s lcd flickers on start up then goes black.
This is typical of a back-light problem, especially when you view the LCD screen at a sharp angle and you see a dim Windows image. This fault is caused by either a faulty inverter board or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp. the CCFL lamp is a mini fluro lamp which fails with age and use.
This LCD screen can be repaired, the cost of an inverter board and CCFL lamp is a lot cheaper than a new LCD screen, but this is an opportunity/excuse to buy a larger size LCD screen as these monitors have dropped in price.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link to their site :-
www.lcdparts.net
Feb 08, 2010 | Computers & Internet
Monitor colour goes pink
The monitor needs to be repaired or replaced, with the low prices today you could pick up a nice LCD monitor.
Sep 16, 2009 | AOC CT720G 17" CRT Monitor
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
SyncMaster 940B
Sounds like you have a video card problem. If it works on someone elses PC and not yours. Replacing this video card on your PC should fix it..
May 14, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Computer monitor flickers
Sounds like the lcd ribbon might have come loose. Or the lcd screen itself needs to be replaced. I have included a link here. The website shows detailed pictures about how to access the parts needed to fix this problem.
The ribbon i'm speaking of is just like the vga cable you use on a normal monitor. Since there is a limited amount of space in notebooks they turned this thick cable into a small flat ribbon.
Try to look and make sure all the connections are tight and as they should be. If nothing changes you will have to change the LCD display.
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
Jan 27, 2009 | Computers & Internet
Can VP171s work with Windows 95?
Your video settings are incorrect for the monitor. Right click on desk top and go into the settings/advance area where you can make monitor adjustments.re resolution and refresh rates.
Mar 29, 2017 | ViewSonic VP171s 17" LCD Monitor
ViewSonic VP171s 17" LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
