Question about JVC MX-D402T Shelf System
Mx-d402t jvc cd player - trays will not open
CD trays will not open on mx-d402t JVC. Not certain if the discs are jammed inside. It sounds as though it is getting ready to open. It also shows as though it were playing; yet no sound. However, sound comes through the speakers when playing the radio. I checked and it indicates the trays are unlocked. I noticed that there is a letter A with an arrow pointed to the right; do not recall if it was like this before. Also cirular arrows above it showing symbol for tape player. I unplugged it to see if it would go back to its original defaults; yet, it remained the same. Any suggestions.
  • Anonymous Oct 12, 2008
    cd player will not open on a stereo everything else works
Just got one of these at the dump. Two problems quickly jumped out at me:
1. As mentioned above, the CD trays stuttered and clattered but would not open.
2. Volume control is unable to be reduced from the highest level (50).
CD tray table was an easy fix.
After removing the 8 cover screws (6 on the back and 2 on the sides) and the 6 tray mounting screws (two through the back and one in each corner) I unplugged the only electrical connector - it is a simple push in pull out type. Note the way it plugs in before pulling out - it doesn't matter which end which you unplug. I set the entire changing assembly aside (outside the tower) on a speaker - just for height because the cable is fairly short. Then hooked the electrical strip back up and turned the power on to the main unit. After setting the controls to CD and pushing the eject button for tray #1 it only took a gentle nudge of the linkage to allow the entire stack to free up. Cycled through the trays several times and each slip in and out as designed.
The next step is not for the faint of heart. Since something (in this case just some cat hair and normal 10 years of dust) was causing the trays to stick it was decided that the entire unit should be thoroughly cleaned. With most electronic devices as long as there is no power on the component it is perfectly okay to wash the entire unit with hot (really hot) water from your kitchen sink. A soft tooth brush and some liquid detergent help the process. After a good long wash and rinse, gently shake as much excess water from the piece and find a supply of warm flowing air. Set the component in front of the air supply and allow it to dry for a looong looong time. 3-4 hours is good.
Hook it back up, cycle the trays and observe the function, paying special attention to where the moving parts make contact. Then shut it down (or not depending on your confidence in your hands) and apply some WD-40 to a q-tip. Using the swab apply a small (the key word is small - you do not want oil based liquids to get anywhere near the CD reading LED) amount of lubricant to the previously observed bearing points. This procedure is best accomplished as the linkages are moving throughout their entire stroke but be careful to not catch the swab in the moving parts.
Now (while I wait for my C changer to dry out), I will trouble shoot the volume problem. If it is something that can be fixed, I will update this post. Please don't assume that just because something has some years on it that one should "expect" it to fail. Oftentimes it just needssome TLC.
Posted on Nov 24, 2008
  • chengny Dec 21, 2008
    Now the volume control issue. I forgot that I had promised to explain this repair - if it was something that could be done economically and by a reasonably accomplished handyperson.
    Good news: It cost nothing to fix and was not difficult at all. From what I read it is a very common problem with these units.
    There is no soldering involved in this fix and if you could follow my instructions on how to free up the CD shelves you can do this fix too.
    Unplug and dissipate any remaining charge in various capacitors by holding the power button in for 10 seconds or so.
    Go back into the unit and remove the CD stack just as before. Set it aside. Looking from the back of the player you will see two rectangular PC boards directly behind the face plate. Notice several of the same type of ribbon connectors as feed the CD stack. Using a Sharpie, or something similar, make marks that indicate which ones go where. Again as before, it does not matter which end is released. Just pick the end that is easiest to get your fingers on. After that it is only a matter of unscrewing about 15-20 phillips head screws and the releasing the two PC boards by wiggling them free.
    I think, if I remember correctly, that the volume control is on larger of the two boards. The smaller board only needs to be pulled to gain access to the main board.
    Now, once you have the board in front of you. Oh yeah, before you do anything. On the front of the face plate you need to pull the knob off and remove the nut that secures volume shaft base to the face plate. The volume adjustor is not a potentiometer/rheostat type of control. It is what they call a rotary encoder - you know the kind of dial that never ends. This type of variable controller does not know it's position it only senses a change in position.
    Take a jewlers screwdriver (slotted) and pry back the four little ears that are bent over the base (which is soldered into the board). Lift the cover with the shaft still passing through it away from the base and turn it over. You will see a circle with 8 -10 maybe little copper arms radiating out from the center. Looks like a pizza thats been cut up. Clean as much junk out of the shell with a q-tip and gently sand the little arms or scrub them with some Comet. Get them good and bright and also the three tiny springy contact points in the base.
    Good luck I am rushing to finish this.
    Problem Solver:
  • 13 Answers
The best remedy is to clean the led reading sensor inside the CD deck.
But, how to do? You must be careful to open the case cover to reach the deck
Rick
  • Rick Foster
    Rick Foster Nov 27, 2008
    The volume of MX- D402T:
    The effecient way to make it work is to replace the exact volume tuning control device itself from the chassis.
    Or make a such repair by softenning the sticky liquid inside the tunning control that serve as lubricant to its contact.
    Try to put a solvent inside the diaphram then blow w/ suffucient air until all get out then make sure that a little push in to tiny pin stripe to stick in its contact to adjuster knob control on the center.
    Repack the the part the resolder it back on the chassis.
    Presto!! Now you can obtain perfect volume sound from zero up to 50.
    How to do is with care and defficulty thats whay be aware.
Its close to 8 years old what do you expect i have one and its trays failed a long time ago
Posted on Sep 16, 2008
I can't get my cdrw out of the recording tray of an xl-r5010bk jvc cd burner
The disc may not have seated properly in the tray on the way in and has jammed inside, preventing the tray from sliding out. Most likely, some disassembly will be required to straighten things out
Jan 08, 2013 | Audio Players & Recorders
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
Apr 09, 2010 | JVC XL-F254BK 5-Disc CD Changer
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
JVC Compact Component System MX-D402T Problem
Hi ryv
The unit may need to be hard reset. Disconnect the unit at the wall and leave unplugged overnight and then try again in the morning, If this does not solve the condition, then it will need some repair work done to it by a JVC Auth service guy.
regards
Graeme
Apr 26, 2008 | Audio Players & Recorders
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
Tray will not open!
press &hold stop then press the eject button.
Nov 04, 2007 | JVC MX-KB30 CD Shelf System
JVC MX-D402T Shelf System Logo
533 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
