Question about Motorola Mobility Boost i415 Cellular Phone
Uploading java games
Hi all, I own a Nextel Motorola i415 and finally i found a USB to motorola cable, however, Im using Midway to send aplications but the phone doesnt answer, i guess i must activate the "upload java" hiden menu option at first, but i dont know how to unlock this. Hope you can help me. It doesnt work with my Serial or USB cable. Thanks.
  • hotpadrino Jan 08, 2008
    Thank you Bumpinjls, that software was so cool! Now i gotta do some J2ME magic for my midlet to work... :S
    Problem Solver:
  • 13 Answers
Try using MyJal Apollo Edition Software instead. I downloaded it and the Crack for it on LimeWire in a zip file for free. It works great. Also you need to download the Motorola USB Cable Driver from idenupdate.com
Posted on Jan 05, 2008
6ya staff
SOURCE:
Failing to send and recieve messages (text) when i have over 50 dollars in minutes. how do i fix this? im using the motorola i415
Remove the battery. Insert battery. Try again. If it fails call tech support. The problem would be int he switch, a software program used to control services that are permitted on the phone number being used. It could be a simple update with the switch that caused your issue.
Jul 18, 2011 | Motorola Mobility Boost Mobile Nextel I215...
I had an old nextel phone it was a i730 and i had to go on the internet on the phone every time i got a text message and i just got a i290 and i still have to go on the internet to send and receive text....
The Text messaging on the I290 is based on Java technology the requires you to go use the web portal..
Newer phones like the i776, i465,i410,i9,i856 no longer require that...
May 20, 2010 | Motorola Mobility Boost i415 Cellular...
How to install games to motorola c650
hi there,
You can download ganes to you phone through different methods like: Over-the-Air (OTA), Infrared (IR), Bluetooth and Cable
1. For uploading through OTA: make sure your wap is well configured and working (each operator has different settings). Enter the .jad url of the game (URL of jad can be found below), then the phone will automatically download the .jad file. After the .jad file is downloaded you will be prompted to confirm the downloading of the .jar file. If you press yes then you can download the file and install the game. Volia! In general you should make sure that the .jar file will fit on your phone. Some devices like Nokia Series 40 (MIDP1) limit the .jar size to 64k, others will limit it to under 100k. Also most devices have a low limitation on the size of all games (midlets) installed, so you should always check the available memory and in some cases remove any old unused games. We have taken the limitation of each device into consideration and there's nothing to worry about here.
2. For uploading through Infrared: First you should get an IRDA peripheral and connect it to your PC. It's usually a USB device. Connect it and install the software.
Now there are two cases:
a. either your phone supports IRDA directly and in such case it's sufficient to upload the .jar file to your phone by right clicking on the file and use 'Send to' menu. Note that you should configure IRDA properly to connect to the phone. We are using the following configuration for SigmaTel USB-IRDA: "Infrared Transiver Type": SigmaTel 4000, "Min. Turn-Around Time": 1.0ms, "Speed Enable": 115200.
b. or your phone doesn't support IRDA directly but has IR. In such case you should use your manufactorer software like Nokia PC Suite.
3. For uploading through Bluetooth: Usually this is faster and easier than Infrared. Install your Bluetooth usb device. Right click on the .jar file and select the menu 'bluetooth device' inside 'send to'. You can also pair your device with your computer to make things faster. Once the .jar file is on your phone then you can install it
4. For uploading through cable: some phones don't have neither Infrared nor bluetooth support. You can use the manufactorer cable and connect it your PC (either USB cable or com cable). In such case you should also use a dedicated software for uploading files to your device
Please use the below mentioned link to find games.
http://www.zgroup-mobile.com/demos/Motorola_C650/index.html
thanks,
S.
Nov 20, 2009 | Motorola Mobility C650
I want to put my nextel plan sim card in the i415 but it says i need a special code wat is the 8 digit special code?
you need to unlock it, try here
http://multiplexelectronics.home.att.net/software.html
you also need a data cable, i think they sell them if you don't have one
Jun 09, 2009 | Motorola Mobility Boost i415 Cellular...
Unlock code for motorola i415
you cannot use a GSM sim card in a nextel / boost mobile phone, if you need it unlocked for iden service you can go here.
if its locked with a passcode, when it asks for the code, hit the menu button, then enter all zeros, if it still does not work contact the site above for help
Jul 08, 2008 | Motorola Mobility Boost i415 Cellular...
My Motorola i415 is locked !
There is no actual "Special Code". The phone is programmed for one, but it won't work. If you can get to a Sprint Nextel repair center, ask them to use RSS to unlock the codeplug. Also note that many Nextel SIM cards will do this to a Boost phone.
Feb 25, 2008 | Motorola Mobility Boost i415 Cellular...
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
when i conect my motorola l6 to my computer it not conect and my computer don't know this usb
Feb 19, 2008 | Motorola Mobility L6 Cellular Phone
Java download
You have to reinstall "Download Apps" with a data cable. Go to idenupdate.com. This is where you get that program. Or take your phone to an authorized Boost Mobile service center.
Dec 05, 2007 | Motorola Mobility Boost i415 Cellular...
Java on the motorola L7
i have motorola l7 and i have 1 GB memory card in the phone but i have send the sons to memory card and i have send the theme also but i don't now where i will paste the theme in memory card and how we can install java games in phone and also softwere
send me full solution how i solve this problem
thanks
PrateekJoshi
Sep 18, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Uploading ring tones
ONE SOLUTION TO UPLOADING RING TONES WALLPAPERS AND GAMES TO YOUR PHONE IS A JAVA APP LOADER AND A USB DATA CABLE.
Sep 01, 2007 | Motorola Mobility i836 Cellular Phone
Motorola Mobility Boost i415 Cellular Phone Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
