Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I lose power when in a cut! Seems to run fine when
By crh2715 on Nov 04, 2009
I lose power when in a cut! Seems to run fine when just reveing up the engine to make the cut but starts to lose power when makeing the cut. This is a Polan Wild Thing. New only a month ago and has given me this proublem from the start!
Best Solution
posted on Nov 05, 2009
Very Helpful)
dontbother10
Rank: Guru  Tools - Building & Power  Expert
Rating: 98%, 847 votes
Your carburetor “H” adjustment is slightly out of whack (probably a little lean). Please call a couple of local saw shops and ask how much to adjust your carburetor. I’d expect to pay $10 – 15. The shop the Pro's use is your best option. A sermon from Lou's pulpit follows, it explains why this happens and why Joe homeowner has to leap many hurdles to correct it.
Before taking it to them: Have a fresh (1.5 months or less) fuel mix with the same oil/fuel ratio (40:1 for your saw 3.2 oz/1 gal - I use 50:1 for all my saws; the next time you have it tuned I suggest you go to 50:1; Use Stihl or Husqvarna 2 cycle oil), are operating at the same elevation where it will be used, and the air filter is clean.
PS I'm Joe.
All new saws regardless of maker are set to run extremely lean to meet EPA mandated air quality standards. They are also fitted with a device to restrict richening the carburetor beyond initial factory settings this too required by the EPA. Most big box stores put them on the shelf and sell them to the consumer with no thought of how elevation may impact saw performance or longevity. Homeowners usually aren't concerned about changes in the saws performance until it quits operating. This combination results in many destroyed saws and homeowner saws of most brands being called trash!
Find a local chainsaw seller/mechanic. If they pull a saw off the shelf and hand it to you without making some adjustment or minimally ensuring it will run hand it back and leave. You can get this service at a big box store cheaper. Find a different seller/mechanic and try again. A good dealer will help you arrive at a saw that will meet your needs. He will ensure it runs properly and you have an understanding of how to properly operate it. Should a problem arise you have somewhere to go and if you were courteous with your dealer someone in your corner helping you rectify your problem.
HTH Lou
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as... (More)
Answer
stihl 038 av problem starting saw.
Answer
the piston ring in my craftsman chainsaw needs changed 2.2 cu in can anyone help
Answer
flymo 2200 chain oil leak when machine is running
Answer
master control lever not working properly.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Chain Saws Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
