Question about Apple iPod nano
Generic mp4 players
Have 4 mp4 players all three will only allow 900mb of info to be downloaded onto them. 2 machines are 4GB and one is 8GB in size via My Computer.
What should I do to fix this problem. I have mp3 utilities version 4.15 loaded onto my PC
Regards
Fiona
How to charge the battery
Posted on Jan 09, 2008
6ya staff
SOURCE:
I have a Telefunken TMP-444B, 4GB MP3/4 player. The setup soft ware disc does not load to any of my computors. Where can I download it. Cannot load music onto the player
Hopefully you got a solution already, but here goes mine: I also had a Telefunken TMP-444B, 4GB MP3/4 and i found you don't need a cd (my cd also didn't work). Try connecting it to your pc via usb-cable and access it on your PC. Simply copy your Mp3 or mp4 files onto it and see it should work. Mine did. Hope yours will.
(Just take care when deleting files, because i don't know if important files are protected on your mp3/4 player). Take care anyway ;-)
Cheers
Feb 05, 2011 | Audio Players & Recorders
Tip
Download DVDs to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/...
Run into fantastic background music on DVD Movies YouTube, MySpace, MSN video, and wanna enjoy the background music on your Sony Walkman? Wanna enjoy DVD movie on Sony Walkman but don’t know how to rip DVD to Walkman? This article will show you how to convert video to Sony Walkman, how to rip DVD to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/ NWZ-S738F, 8GB) for your watching.
The leading role of this article is Daniusoft Video Converter Suite which is an applied Sony walkman video converter, it is already optimized for output setting for Sony Walkman video (*MPEG-4)/Audio(*MP3) in its profile. Very easy to use, like the follow illustration:
Okay, without further ado, let’s cut to the point to get things work.
First of all, Download Daniusoft Video Converter Suite, after installing it, you will get 2 apps: DVD Ripper and Video Converter.
Next, run Daniusoft DVD Ripper software to convert DVD to Walkman-friendly format: MPEG-4. The nifty walkman DVD converter has all essential functions such output profiles, parameter settings and video editing. The detailed conversion process is showed as below:
1. Click 'Load DVD' button to add the DVD file. You can also click 'Load File' to add DVD/IFO from your hard disk. (Ensure that you have sufficient space on hard drive to store the DVD).
2. Select profile "Sony Walkman -> Walkman Video (*.MP4)".
P.S. If you wanna extract background music from DVDs and convert to Sony walkman, Just Select profile "Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)".
3. Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
4. Click "Edit" to adjust effect, length, size and watermark, etc.
5. Click "Start" to convert DVD to Sony Walkman.
Using Daniusoft Video file Converter to extract background songs from YouTube, MySpace, MSN video to Sony Walkman is as easy as Daniusoft DVD Ripper.
1. Run Daniusoft walkman Video Converter and load your video downloaded from YouTube, MySpace, MSN, etc.
2. Select profile "Convert to -> Common Audio -> MP3-MPEG Layer-3 audio (*.MP3)".
P.S. If you wanna convert your favorite web-video files from YouTube, MySpace, Facebook, MSN etc. to Sony walkman, Just Select profile "Sony Walkman -> Walkman Video (*.MP4)".
3.Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
5. Click "Start" to convert video to Sony Walkman.
Now, you can connect Sony walkman to computer and copy these converted DVD video or background music to your Sony walkman (NWZ-S618F/NWZ-A818/NWZ-S616F/NWZ-S738F) player. Using the Daniusoft walkman video converter well can cover the boring journey on a bus or a plain with myriad happiness and fun.
on Mar 29, 2010 | Cell Phones
I do not know how to get my music onto my craig 4gb mp4 player. i have the mucic, but it is telling me that it's not connecting. I know there is no problem with the USB connection either. This problem also...
Use Windows Media Player or iTunes program. You need one or the other to transfer music to it from a computer. The program will detect your player.
Jan 08, 2011 | Cameras
My Sanyo LCD 40XR10F TV does not recongnise any mp4 movies i have on my external hardrive or usb stick?? Does it matter what size usb disk/drive/how many files are stored on them for it to play them?
Before you loaded the hard drive, and USB did you run a "Check File System" through the TV? These devices in order to use the "Time Shift Function", have to have pass with "SUCCESS", displayed on the screen. If not the TV will format a 4GB FAT32 filing system for you. The reason your MP4's might not work might be due to a firmware update that no longer supports MP4. You should have been OK if you recorded the material from the TV. Items you record from the TV will not play on any other device. Using the FAT32 format only allows 4GB but, the TV allow 8GB and a external device can be FAT32 format to 8GB. 8GB is only 2 hours of viewing time. So that should give you some idea how little the amount of files can be handled.
Dec 21, 2010 | Sanyo Televison & Video
Not able to copy movies on Sony 8GB Memory Stick Pro Duo for PSP
Before you go throwing any old video file onto your PSP, make sure you have the following items:
  • The PSP. This is self-explanatory.
  • The .MP4 video files.
  • Video conversion software to convert non-MP4 files to MP4, the format the PSP reads.
Oct 20, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Just bought an Ematic 1.5%22 Color 4GB MP3/4 Video Player and the driver disk it came with about 3'' wide much smaller than a std cd so i cant use it. where can i get the driver and anything else to make...
You should be able to use the small diameter disk. The disk can be inserted in the CD/DVD drive just like a normal size CD/DVD disk, it locks onto the spindle on the laptop's CD/DVD drive. The laser reads from the center of the disk.
Oct 16, 2009 | Dell Inspiron 1501 Notebook
Mp4 players os is dead
You have been sold a fake sized player. it is hacked to show 16GB/8GB actual size may be around 1GB to 8GB or less. test your player with "H2TESTW 1.4" you will find it the first hit on www.google.com let other people know and open a dispute on paypal, you have been sold a fake item. Do not return the item for refund as sellers address is very likely wrong, useless to wait for a replacement player because they all are hacked. Get a partial refund if still possible and leave negative feedback.
about the other problem your having, I don't know about that. I'll let you know if mine breaks up. its a 16GB version that actually has only 4GB. got 20usd refunded from the original 35usd, so not a big problem.
still I think its a crime yes? to sell counterfeit products / manipulated to show incorrect size of memory etc.
Jan 02, 2009 | Apple iPod nano
Mp4 Player not recognized....???
ina mo!..
that's easy!..
you just have to reformat the mp4 player!..
Sep 28, 2008 | Apple iPod nano 3rd Generation
4gb Mp4 Player problem
and i,ll bet it was from China or hong kong ?
go into settings, there you should find options to set the defaults for the timer, its probably set for 15 or 30 seconds.
these don,t have a huge capacity for video, but this might help.
you wont play a full film, probably about 3-5 minutes storage Max.
Mike @ Compurepair.
Feb 25, 2008 | Audio Players & Recorders
Generic 8GB Flash Mp3 player
try a firmware update.....sound to me like a firmware fault???
Sep 13, 2007 | Samsung YH-925 MP3 Player
Apple iPod nano Logo
114 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
