Toshiba TZ55V61 Hi all, My TV has shaded text appearing lately, and I have been reading about it. It sounds like I need to replace IC's. Being not a TV tech but know PCs well, will this be something like replace them by pulling out and putting new ones? Will it require soldering? just wondering if I can do this and myself or a TV tech is essential? Kindly advise. Thanks.
  • k_nick_99 Jan 05, 2008
    thank you very much! following your suggestions I was able to use the arrows to shift the colors red and blue to align with the + on the center of the screen to make it white. Until now I did not know how to set it, although I had seen the screen several times and I was not setting it correctly. Followed your instructions and bingo! Phew, now I don't have to mess with IC's.
    Thanks
    Nick
    Novelist:
    Champion:
  • 232 Answers
Hi, I`m assuming your saying the letters on the screen have different colors (red, blue, or green) shifted to the left or right?
If so try going into the menu and adjusting your "convergence"
adjustments, basically, move the red onto the green then move the blue onto the green and the bar turns white, if one or more of the colors doesn`t adjust either up/down or left/right then the convergence IC`s have failed, this will require removal of the board and unsoldering the old IC`s and installing and soldering in the new IC`s, questions? e-mail me back, BMW Rider
Posted on Jan 04, 2008
  • Larry Eastman
    Larry Eastman Jan 05, 2008
    Nick, glad it`s fixed, would you please give me a fixya rating on my answer, I`d appreciate it, BMW Rider
When you try to turn the tv on, all you get is a blinking red light, if you unplug for awhile, sometime it will come on.
Symptom: tv turns on, tv clicks once, red light comes on. Then, tv either works for a while, followed by a click, no video, normal sound and flashing red light; or, tv immediately clicks, no video, no sound, red light flashes. If that is the problem, you need to replace the convergence ICs. I had to do this twice. The two convergence ICs are mounted on palm-sized aluminum heat sinks. The heat sinks are soldered to the main circuit board. There are 4 pins soldered to the board for each heat sink, and 18 pins soldered to the board for each IC. Some of the heat sink pins are a bit difficult to desolder. The pins for the ICs are not difficult to desolder, but you must be careful not to overheat them. The heat sink and the IC come out as a unit, after all pins are desoldered. The IC is screwed to the heat sink. The correct replacement IC is a Sanyo STK392-110. I got mine from B&D Enterprises. They were not expensive. The new ICs need to be mounted to the heat sink with a heat transfer paste. I used Arctic Silver from my computer processor heat sink. Installation of the heat sink/IC assembly is a bit tricky, since you have to align all 18 IC pins and the 4 heat sink pins. When all the pins are visible through the holes in the circuit board, resolder everything. The TV should now work. Be sure to replace both ICs. My first repair was done by a technician, who obviously only replaced one. That repair only lasted a couple years, before the problem returned.
Mar 22, 2011 | Toshiba TZ55V61 55" Rear Projection...
My screen ripped i need to replace it where can i perchase one for my toshiba model # tz55v61
I own this TV and it no longer works. I am willing to sell the screen. Please contact me at ljtebbe@gmail.com
Feb 10, 2010 | Toshiba TZ55V61 55" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
Toshiba 55" rear projection
Hi, convergence circuit has failed, the IC`s will have to be changed,possibly a couple of precision support resistors as well and the set will then need to be re-converged, More questions? feel free to ask away, Happy Holidays, BMW Rider
Dec 10, 2007 | Toshiba TZ55V61 55" Rear Projection...
Toshiba 55" projection TV
this is a stupid question but is the mute on?
otherwise sounds like an audio chip is bad.
Dec 03, 2007 | Toshiba TZ55V61 55" Rear Projection...
Tosiba TZ55V61 Convergence IC 150?s vs 110?s
STK392-150 can be replacement for 110's no other resister values need to be changed, however be sure bad resisters are replaced and check all the resisters (6) have been taken out of circuit and checked. also check for solder cracks and cold solder joints.
Dec 02, 2007 | Toshiba TZ55V61 55" Rear Projection...
Toshiba TZ55V61 having prob. w/red,yellow lights
Convergence issue...replace STK392-110 IC's on small PCB
mounted by itself above power supply....................T.
Nov 08, 2007 | Toshiba TZ55V61 55" Rear Projection...
Problem with Projection TV
This set is very common for the str typr power regulator to go out on it. Its not a consumer replaceable part. Please find a trained tech to assist you with this repair. Good Luck
Aug 09, 2006 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
