Question about Philips Magnavox 51MP392H Rear Projection Television
Replaceing how to find were to locate and replace bad power supply
  • 232 Answers
Hi, cheaper to repair the module than replace it but you should be able to buy one here if you want to,
good luck and be sure to mark ALL of your cables/plugs as you remove them so you will know where to put them when your ready to install the new module, if you plug something in the wrong place they will NOT warranty the new module, BMW Rider
Posted on Jan 04, 2008
How do i know if my power supply board is bad
Pluck out your power supply board, from where it is now; and replace it with an other. I think, the location of your power supply will be somewhere between your legs.
Nov 03, 2016 | Televison & Video
Power source does not work. Wont turn on or off
Blown fuse or bad capacitor on the power supply. the set and remove the back panel. Locate the power supply. There is usually a fuse in line with the hot supply wire. Check it for continuity with an ohmmeter. Look for bulging electrolytic capacitors on the power supply. Electrolytics are polarized (+-) and can fail if they go even slightly overvoltage. Replace bad capacitors with components with the same microfarad rating but a slightly higher voltage rating. I.E. replace a 16 volt cap with a 25 volt cap.
Jul 23, 2014 | Magnavox 32mf231d
How to fix the inside of the bestec
Not worth the trouble. By the time you locate the bad part, find a replacement put it all back together and hope nothing else goes bad, you have the price of a new one.
Jan 11, 2014 | Bestec (ATX-250-12E) 250-Watt Power Supply
Where can I get power supply board (PS 641A352) for Mitsubishi TV model CK-31304 ?
the board is no longer available---in these sets it is find the bad part and replace it, not board replacement. The relay if bad (rare) should have all the info printed right on top of it to locate a replacement.
By the way, if you think its bad because it clicks on and then off---the contrary is the case---if set has a problem relay will turn off.
Apr 15, 2012 | Televison & Video
50 inch lg won't power on
The problem could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes
If otherwise you have to change the whole power supply board Power supply board just die.It can be dead at anytimes.Tries websites, to buy a refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Sep 05, 2011 | LG Televison & Video
Standby power no picture
The problem in general (as this question is) would be to inspect the power supply. The power supply board, in the TV will have bad capacitors. You will need an ESR meter to locate and replace bad capacitors. You may look for bulged or skinned caps, if you do not have an ESR meter. If you have an external power supply ( a black electrical box transformer, from ac wall outlet, with another cord that enters the TV) the problem is inside of this. Once again, you will need to replace caps here, thanks for asking and show all hands of support!
Aug 03, 2011 | Televison & Video
Power source out
You will need to inspect the power supply. The chances are real good you have bad capacitors in the power supply. I would estimate there will be 5 capacitors that will be replaced. You may change them all, which is best. Some capacitors will check good when they are not. The power supply will be the smaller of the two boards inside this TV. It is also the easiest to pull out. You may use a capacitor checker to locate the bad caps. This is know as an ESR meter. Once again, it may show a good cap when it may in fact be a bad one. This is rare of course, but I have been there. Please replace all caps in the power supply board. If there is a good capacitor it will be the 400 volt 100Mf (Largest capacitor in the power supply) that is fine! Thanks for asking and show all hands of support.
May 21, 2011 | Protron PLTV-32 Television
My toshiba satellite L25-S1193 does not power on at all. Should i replace the power supply. If yes, where is it located.
Most likely either u have a bad motherboard,bad DC jack, or a bad charger. The Toshiba's are notorious for bad DC jacks however they are one of the easiest laptops to replace one on because they arent soldered to the board. Think u need to have a shop run down the exect problem b4 you start replacing parts. Ur power supply on a laptop is the charger cord and or battery they are not like a desktop.
Aug 16, 2010 | Toshiba Satellite L25-S119 Notebook
TV does not appear to be powered. Either fuse or power supply
The fuse is in the power supply. It's a slow blow fuse rated 250V 5A.
Jun 02, 2009 | Syntax Olevia 537H Television
Philips Magnavox 51MP392H Rear Projection Television Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
