Red light is flashing, no picture or sound I have a toshiba 61 big screen that will not turn on if the room is under 65 degrees. The red light flashes and I have unplug the set to reset. Once the room heats up and I reset it works fine.
  • 8,617 Answers
You have a thermal problem in your start up. Radio shack sells a chemical called component cooler that can help you isolate this problem. Power your set up to operating temperature.Then cut it off spray one section of the start up circuit to cool it off then try to power up your set. If it doesnt power up try a hair dryer on the section you just cooled and try powering it up. If it powers up you found your problems. Hope this helps. Let me know if you need any additional advise.
Posted on Jan 04, 2008
6ya staff
SOURCE:
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
65 hd projection tv -no picture-red power light is flashing-help
There are many circuit failures that can cause the TV to do this. By far the most common issue is a failure of the convergence output ICs. Expect to spend $350-450 to fix this.
michtech
Feb 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Turned the big screen toshiba theatre view on, worked good for about 2 min. Then just shut down, not the red power light comes on, but no picture or sound.
water from air conditioner dripped on back of 56in.toshiba big screen.now its has no sound or picture.its been sitting for 2yrs and has had just a good as picture a smy flat panel.every 1 says im stupid for keeping it but iwould like to know if it is doable by me.i believe i could do it if i knew what part i needed.thx
Aug 28, 2008 | Televison & Video
NO Picture
sounds like the power supply went out
Aug 22, 2008 | Hitachi 61SWX10B 61" Rear Projection...
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
