KDF60XF955 LCD Projection TV
This had the standard problem with this model of a failed lampovertempdevice. Installed Sony's A-1137-954-A kit and restoredlamp operation, but now have no picture but do have sound. Did Ido something wrong in taking everything apart to put in the newtempdevice or ???
  • Greg Collins Jan 04, 2008
    As I said, the lamp is now working, but no picture is displayed. Lights up but no image. Somehow lost the signal driving the LCDs.
    There is that special LVDS cable that hooks up the B board to the C board. What a piece of work that is. Ever have trouble with that?
  • 4,102 Answers
HI did you just replace the temp device are you sure the problem wasnt with the lamp itself.
As the sound is working you know your getting power through the telly so that isnt the problem.
The best thing to do is have a look at the resistor around where the lamp is joined to the board check with good lightin and magnifying glass and look for damaged or melted resistors.
Because the problem is if the lamp has gone then it could be a resistor that caused the lamp to go.
So if you change the lamp and a resistor has gone it will just cause same problem.
Is the lamp working or not.
And when the telly stopped working did you lose the sound as well. All these types of telly have the same problem with the lamps and the resistors let me know how you get on ok
Posted on Jan 04, 2008
  • paul proctor Jan 04, 2008
    Hi you will need to check that all the cables are sitting in correctly as they are difficult to do they should only go in one way.
    As the lamp is working fine then the chances are the problem is with a connector somewhere make sure they are fitted properly but remember dont touch anything on the board as the static in your body can short the board out.
    When the lampovertempdevice went did you lose everything and it just shut down.
    its difficult for me to tell you as i cant see the telly in front of me but as the lamp is workin you know the tempdevice is correct.
    So i would check all cables are fitted securely then try again if still no joy then it could be a case of looking at the resistors around the input devices where you plug the dvd in and have you tried getting a picture that way through dvd that would narrow it down a bit.
    Anyway you will need good ligh and good magnifying glass and check all resistors because when the temp device went this could have blown a resistor so check the resistor around that area. But just check all leads first as this sounds like your problem.
    Be carefull not to touch anything else though as this could cause further problems let me know how you get on
    Genius:
  • 1,153 Answers
No you didn't but sometimes when lamp goes out there is a fuse also goes with it. If the new worked for a short time or never worked then I woul look for an open fuse. I would need schematic to find. Are you can keep asking here until someone give more helpful info.
I have a sony widescreen projection tv model KP51WS510. the picture has shadows and shows double.
Thats caused by failed convergence ICs your model uses the STK392-560 ICs you will also need several 3.5 amp pico fuses and a couple of 5 amp pico fuses to do the repair. The Sony Type 1 convergence repair kit is the correct kit for your model. It contains the parts and the CD with repair instructions. The kits available from www.tvrepairworld.com
Aug 09, 2011 | Sony KP-51WS510 51" Rear Projection...
Sony LCD TV Model #KLV-23HR2 The timer LED blinks red constantly after having turned on the TV. THe power light stays steady green for about 5-10 seconds then the red light keeps blinking constantly.
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 27, 2011 | Sony WEGA KLV-23HR2 23 in. LCD HDTV
SONY LCD MODEL KDL-46v4000 blinks 6 times before shutting down. Please note that Main power supply board and digital board have been changed, but problem persists ! Would be grateful if you can guve some...
Apr 27, 2011 | Sony Bravia KDL46V4000 46 in. LCD TV
My Sony Grand WEGA KDF-60WF655 60 in. Rear Proj. HDTV would black out no pic., no sounds every 5 to 10 mins. with the power light still on. Ive changed the power saver mode to low and it stop blacking out...
There is a know issue with certain Sony models where one or two parts fail over time due to heat. Check the site www.TvRepairKits.com to see if they have a blinking green light kit for your model. Its a fairly common problem.
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My kp57w5500 has a double red image on everything i watch... seems like im looking at a 3-d tv only it is not lol. Is this a fixable problem or am i just better off buying a new tv?
Thats the classic sign of failed convergence. You can get the Sony type 1 convergence repair kit which fits your model from www.tvrepairworld.com the kit contains the ICs, Pico fuses and etc. plus the cd with instructions for the repair.
Oct 22, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a sony E50 A10 rear projection TV and the blub went out and I replaced it. It was ok at first, but now I am getting blue shadowing along the bottom of the screen and it shadowing also appears in the...
You have a failing optical block. Sony is covering some of their rear projections LCD TV's for such a symptom like this. What is the complete model number and I can check to see if yours is one. The model will be like KDF50....
Aug 28, 2010 | Sony Televison & Video
Why is my television 3D?
The convergence ICs have failed. The Sony type 1 convergence repair kit is the correct kit for your model. The kit contains the parts and the CD with instructions. You can get the repair kit from www.tvrepairworld.com
May 09, 2010 | Sony KP-51WS510 51" Rear Projection...
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Televison & Video Logo
319 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
