LG WM-2277HW Front Load Washer
Problem for LG WM-2277HW Front Load Washer
LG LE error. WM2277HW Have replaced the Hall Sensor and ran
By cclark927 on Nov 04, 2009
LG LE error. Have replaced the Hall Sensor and ran a load on sanitary with vineger it worked fine for about two weeks now its back and I am having a meltdown over this. What to do?
Comments:
Nov 04, 2009
- Tide HE detergent, 2 tablespoons per load.
Clarification Request
Posted by MNTECH on Nov 04, 2009
Tell me what kind of soap you are using, and how much.
Best Solution
posted on Nov 05, 2009
Very Helpful)
MNTECH
Rank: Guru  LG Expert
Rating: 94%, 927 votes
As long as that Tide HE is not 2x or 3x concentrated, that would be the maximum amount of detergent for a large, heavily soiled load. Lighter soiled and/or smaller loads should be about 1 tablespoon. If 2x concentrate soap, use only half that. The reason this could cause an LE error is that suds between the inner and outer drum will cause excessive drag on the inner tub, with the possible result of an LE error. I'd try to run a load on Sanitary, heavy soil level, with no clothes, and a washer cleaner such as Affresh, Washer Magic, Whirlaway hot tub cleaner, Smellywasher cleaner, or Tide washer cleaner to remove any possible build up of soap residue from the outer tub area.
Sometimes, cycle selection/ loading level/ load type can cause LE errors. Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
Another possiblility would be a loose electrical connection dealing with the Hall sensor, at the sensor, the control board, or (much more unlikely) the wire connecting them.
On rare occasion, the main control board can be at fault, but generally, replacing the Hall sensor does take care of the problem. (over 90% of the time)
Comments:
Nov 05, 2009
- Thanks for the feedback. We like to know how things turned out.
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" Right on with the solution...After fully disassembling the washer ohming all the wires checking all connections. It turns out a loose hall sensor. " - cclark927
Solution #2
posted on Dec 19, 2009
Not Rated)
FLORIDA2009
Rank: Apprentice
Rating: 92%, 3 votes
Here is some more info for anybody that needs it.
I ran into the same LE error on our LG washer. Tried replacing the Hall Sensor which did not fix the problem (Intermittent LE error).
Here is what I found: I had a cracked solder joint on pin W of my motor harness connector (RD1) on the main circuit board. This caused a intermittent "Open" circuit indication to the computer which causes it to stop spinning and indicate "LE" on the display.
I had to remove the pink connector from my circuit board and dig out the humiseal around the other side of pink connector to gain access to the soldered in pins. Pin "W" just pulled right out when I removed the pink connector on the circuit board. I soldered the male pins back in place and also soldered the female motor wire pins right to the male pins coming from the circuit board. Wrapped electrical tape around them and I'm now operating with no "LE" error for now. I suspect that this is a VERY SIMILAR cause to alot of the "LE" error trouble people are getting. Here is a link to my website with pictures of what I did.
www.bobamy.net
Was this helpful?
Yes
No
Popular Solutions for LG WM-2277HW Front Load Washer
Questions and Unsolved Problems for LG WM-2277HW Front Load Washer
Do you recommend LG WM-2277HW Front Load Washer?
Answer
Answer
drum will not turn in wash cycle and make squeeking sound
Answer
i would like to remove the door gasket to clean under it
Answer
Jon, thanks for your answer. What do you mean get to the pump from the bottom. Do I have to turn the... (More)
Answer
i have a lg washer front loader and it is leaking every time i use it. the water level is not there... (More)
Answer
clothes don't smell clean. I have increased wash times,amount of detergent,run cycles with bleach to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , TX
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
